03-03-2008, 02:58 AM | #1 |
Eng ID
Is there an easy way to tell if an I6 is a 250 or not with out looking at the engine number? Planning a trip to the pick & pull.
Thanks, Guy |
03-03-2008, 03:59 AM | #2 |
member #16
Re: Eng ID
I think the engine mounts are straight across on a 250 and offset on a 292. there are other diff's ,but the mounts are the easiest way.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
03-03-2008, 06:08 AM | #3 |
is Certifiable
Re: Eng ID
The lifter covers on the 292 are 6 inches tall I believe. And 4 inches tall on the 250.
03-03-2008, 06:14 AM | #4 |
Re: Eng ID
I have a 250 6cyl in my truck now and the plates are 4" and the mounts are straight across. both those guys are right on the money.
If your not living for something, your dieing for nothing... |
03-03-2008, 08:29 AM | #5 |
Re: Eng ID
Telling the difference between the 292 and the rest is pretty easy as the others have mentioned, but telling the difference between a 250 and say a 235 is a bit thougher. Even if you run the numbers on mortec.com, mine showed that it was either a 250 or 235. Seems the best way to really tell is to open it up and look at the pistons. If they are dished then it is a 250. Sounds suspicious I know, but that's the best I could come up with. All was confirmed once I measured the bore though.
Sorry this wasn't more help. Shawn
-- Shawn '67 Short Step '70 Short Wide |
03-03-2008, 09:20 AM | #6 |
Re: Eng ID
This might be overly simple but on my 67 glove box sticker the options is listed as
L25 292 CU IN I-6 ENG
1967 Chevy Fleetside with an amature behind the wrench |
03-03-2008, 03:03 PM | #7 |
Re: Eng ID
I love it Pick up Box floor, never knew they didn't come with one,
Glad mine had it.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
03-03-2008, 11:49 PM | #8 |
Re: Eng ID
Its a Fleetside with the wood floor option haha (AKA Temporary floor, its rotted away now)
