Old 03-04-2008, 04:12 AM   #1
bdydrp97s10
bdydrp97s10's Avatar
what backspacing for bagged 68
im sure its been brought up before..
i have a 68 c10, with a 73 front crossmember and rearend.. 5x5 lug pattern.
what kind of backspacing do i need if i bag the truck
bdydrp97s10 is offline   Reply With Quote
Old 03-04-2008, 06:32 PM   #2
n2billet
Village Idiot....
n2billet's Avatar
Re: what backspacing for bagged 68
20x8.5 with 5.75 BS for the front
and 20x10 with 4.75 BS for the rear
255x40 front
295x40 rear
This is what I have on my 68 but you may want to go to 5.00 BS on the rear. I had to do some mods on the inner metal on the bed to clear the tire. I wanted the tire as close to the lip as possible so that is the reason I went with the 4.75, the 5.00 might resolve this issue.
Hope this helps.
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 03-05-2008, 03:05 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
The '73 rear is 1.5" wider. You will need more backspacing- like 5.5 on a 10" wheel. You can get away with 5.25 on the front with an 8.5" wheel...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-05-2008, 03:21 AM   #4
shifty
Questionable
shifty's Avatar
255x40 front
295x40 rear
Hope this helps.
Is this the setup you used on the "Extreme Makeover" truck(lucy)? Stock '68 rear on that one, with '73-87 front crossmember using stock arms?
Just checking - if so, my ride is cloes enough to the same, only I'm using ART arms.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-05-2008, 04:20 AM   #5
SCOTI
SCOTI's Avatar
Yes, that's the set-up.
Up front, an 8" wheel uses 5.25 BS; 8.5" wheel uses the 5.75" BS. The 71-87 rears need more BS than 67-70 rears because the 71 & later housings are wider.
We both are using 68 rear housings. N2Billet left his wheel tubs the factory width & re-worked the inner-tub thats tucked up between the inner/outer bed-walls. I mini-tubbed mine 1.75" & left the inner-tub alone. Either way works.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-06-2008, 04:26 AM   #6
bdydrp97s10
thanks for the info guys...
Old 03-06-2008, 04:54 AM   #7
n2billet
Village Idiot....
n2billet's Avatar
What Scoti said.....
