Old 03-06-2008, 05:03 AM   #5
streetmaster42
Re: Need info on a return line back to the fuel tank
Ok im starting to get whats going on with this emissions thing. Ill take that line with the hose on it, (Off) and run it back to the charcoal can, and be done with that. I now have to figure out if the PSV on my 350 splits off with one hose going to the char canister, and the other to the carb. Or if the PCV just goes to the carb. I know that the EGR goes to a TVS switch, but the hose from the TVS goes to the carb, aswell as the vacume advance, the mod valve for the TH350. The big problem im dealing with is, i have 1405 Edelbrock performer series carb that only has 2 small vacume port in the front of it. The one on the left is constant, and the one on the right is not. Do i (T) off the vacume advance with the hose from the TVS hose. Theres also the hose from the charcoal canister that goes to the carb, not sure if it needs to be hooked to a constant port or not. I guess what i need is a detailed list of how i can make all this work with the Edelbrock carb.
streetmaster42 is offline   Reply With Quote
