Chevy nut
No Lights
I bought a 87 GMC (also know as Got Mine Cheap!!
) Someone stuck a 283 out of a 65 Impala in it. They blew the 700R4 out of it. So I got a truck with no trans and no headlights. I got head lights for it to day. I took the 283 out and put it on the floor...there is no accessory holes in the heads. The P/S and alt was rigged up to work. So the problem I have ran into...I hooked up my battery charger to the frame and to the starter wires (they are still hooked up the the starter laying on the frame) I have turn signals and brake lights...but no head lights, Marker lights, tail lights or inside lights. The motor started up while it was in the truck. The dash lights (seatbelt and warning lights worked) but no dash lights. I hooked the hot side of the battery charger to the head lights and they came on...so did the dash lights, markers and tail lights. Any Ideas?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Re: No Lights
The power to the headlights comes in to the headlight switch. Check the switch for power. if you have power there. next check going into the dimmer switch. If you have power coming into the headlight switch and none going out to the dimmer switch replace the headlight switch. If there is no power coming into the headlight switch, you need to replace the headlight relay. The only other possibility would be cut wires. does the parking lights work?
#3 | |
Chevy nut
Re: No Lights
Re: No Lights
I would say you have lost the power coming into the headlight switch. Start checking at the switch and back track till you find it.
Chevy nut
Re: No Lights
I am going out to work on it today sometime. Hopefully I can. I got a 350 short tail for it today.
Chevy nut
Re: No Lights
Yes it was something stupid. The alternator wire needed to be hot too. So I hooked it up and everything works now. Thanks.
| Bookmarks |
