03-06-2008, 09:39 PM | #1 |
Engine n00b
Is this everything I need to go 5 lug with disc brakes?
I *think* it's all I need. The only part I am unsure of is the rear drum backs.... Is this more a complete rear axle swap off CL/ebay? |
03-06-2008, 09:46 PM | #2 |
Self-proclaimed LED man
Re: Is this everything I need to go 5 lug with disc brakes?
For that price, you could just buy my 72 2wd
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
03-06-2008, 10:14 PM | #3 |
i hope that includes brake lines, proportioning valve, and master cylinder......
03-06-2008, 11:04 PM | #4 |
Chevy nut
I gutted a 77 for my parts...I am getting new ball joints, tie rods, master cyl, rotors, calipers and brake pads. For the front end its 144.00. I gave 150 for the truck...the 77...and I scrapped most of it and sold parts of it so it paid for its parts for the 69.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
03-06-2008, 11:08 PM | #5 | |
Engine n00b
Maybe on brake lines, not sure. And yes, my jaw dropped at the prices too. The sad part is, the only reason I care about 5 lug is easier/cheaper wheel selection. Its looking like the cost savings may not be worth it. |
03-06-2008, 11:52 PM | #6 |
Depending on who you ask, 5 lug may help the resale value. (That is if you ever sold it...)
03-07-2008, 12:25 AM | #7 | |
Engine n00b
Ive decided to dro pthe 5 lug conversion and disc brakes for now and concentrate on the more problematic issues. She stops fine for me as is. |
03-07-2008, 01:01 AM | #8 |
You could swap in a 73-87 front if you could find a donor in good shape. That'd save you a good bundle.
03-07-2008, 02:07 AM | #9 |
im in san marcos - welcome to the board.
that is alot of coin. depending on what year you got - the rear axles may be a different length. i purchased a 5 lug rear from CL (71)for 150 and it bolted into the 67 frame used 80ish front sus. 150. had to get different spindles - there is a difference in the later 80's on spindles - light duty and heavy duty - you want the heavy duty if you deal with ordering parts for bearings etc. rear BlackBird rear disc kit 550ish there was a guy parting out a 71 in S.A. on CL last week - i would check on the brake system good luck |
03-07-2008, 02:11 AM | #10 |
Whoa!!!
No Limit has the drop spindles and disc brakes with hoses for 450.00!!!!!!!!
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
03-07-2008, 02:11 AM | #11 |
I used it on my truck,
includes spindles, rotors, calipers, pads ,bearings and hoses.
03-07-2008, 06:13 AM | #12 |
the boat guy
also if you buy a donor truck you get a set of 5-lug wheels, so you can get back on the road again before dropping major coin on a "nice" set of wheels. right now i just have the front half done on my truck, drives fine, looks ghetto.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
03-07-2008, 07:41 AM | #13 |
I used my original dog-dish caps on my 68 using OE 5-lug wheels in front & 6-lug wheels in back. You would never know it unless you told someone what's hiding behind the hubcap.
