Junior Member
![]() Join Date: Feb 2005
Rear Swaybar For My 48 Gmc Panel?
Currently have TCI front suspension, Leaf rear with a 57 Ford 9-inch about 57 wide to accomodate the 10 inch rear rims. Thinking about a purchasing a BROTHERS rear sway bar ($250) ANY SUGGESTIONS?
Re: Rear Swaybar For My 48 Gmc Panel?
I think with that high of C of G it would be very benifical for you,
you should notice a big difference.
Check with the Rob at No Limit Engeering, I think he has one for the Ford Panel, should be about the same deminsions
Junior Member
THANKS SOLIDAXEL!
Saved $70 at No Limit! ![]() |
BBeep can you upload picts when you get them?
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
I guess he had one for a Chevy, is it the right width
,does it come with poly bushings, how much fab work do you have to do? I have been looking at his 4-Bar set up. Sometimes it is cheaper to go to the manufacture than the Re-boxer, I wonder who Brothers buys theirs from?
nice truck! update up with pic's and if you needed to fab anything or if it was straight bolt on.
Junior Member
Part on backorder. I'll let you know when it lands!
Junior Member
Junior Member
But, hey, it gives me a chance to do a couple of other things. I built this truck in 98-99. and actually used it for my Delivery Service in Eugene. It just turned 70k on its most recent life. For about three years it was my only delivery vehicle for me to personally drive and I logged over 50k.
SO anyway, updating it by replacing the wheels with 17 & 18 Foose, gonna drop the back 2 inches, pulling aluminum wheels and aluminum Briz bimpers,--replacing both with chrome. Just give it a new look without re-doing the whole truck. ![]() |
I think you might need to drive through Pleasant Hill and tell me if it still exists. Just East of Eugene. You know where it is. The Butte used to be a great walk on the 4th of July. Does it still work or has it been contaminated? My memory fails me. Spencer's? Skinner's? The tall one on the South end. You know. David
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched Last edited by DavesRide; 03-01-2008 at 08:29 AM. Reason: Poor map directons |
Junior Member
P HILL? Drove through tonite, Bermuda Triangle--my truck ran out of gas--right after I filled it up! Spencers South, Skinners, down by the riverside.
Junior Member
Had to cancel the swaybar. I had the truck on my hoist yesterday and realized that my extra gas tank , located directly behind the diff, would create too many clearance problems. I guess I'll have to slow down to the recommended speed on those hard corners!
bummer dude! i was looking foward to seeing it installed on your killer panel.
