03-08-2008, 12:19 AM | #1 |
__Power Steering pump mounting
Anybody have handy a photo of how the steering pump mounts on the frame side of truck?
I have my pump bolted to the 454 out of the truck - looks like maybe there's another mounting point toward the wheel (extra flanges/holes in brackets on wheel side)? Thanks. |
03-08-2008, 03:45 AM | #2 |
STILL PLAYS WITH TRUX
Re: __Power Steering pump mounting
Dude,...........I have no idea what it is your asking and i don't think anyone else dose either.
Your wording in the ? is very confusing. I know sometimes things can be hard to explain and even harder to write it out so maybe if you edit it some and reword it then someone may be able to help you out. I can tell you this much the Steering Pump is mounted to the Engine via the use of several brackets between the head and block, But not the frame. The Steering Box is mounted on the frame via several bolts. I hope that helps. |
03-08-2008, 05:22 AM | #3 |
Sorry 'bout that - I'll try to get a pic or two and post this weekend if I don't get a chance to stick my head under the hood of a later model truck - it IS confusing looking at the brackets.
