Inside Door handle mechanism ??
The thing that the door handle mounts onto, is it supposed to be stiff (spring back into place) or loose? Is this thing interchangeable with other years? Anyone?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
It is supposed to be spring loaded, although it is not terribly stiff. They still work if the spring breaks, you just have to be sure the handle is in the closed position before the door will close correctly.
I don't know if they interchange. I think the door panels on the later years would require a longer shaft on the mechanism, but that is a guess. My drivers door one is broken (no spring) while the passenger side still is springy. OCB |
KEEP ON TRUCKING
they are not hard to replace and i would.i kept saying no need and my son was10 then on a deadend road he said daddy spin it around and i did door come open he went out and almost run over him he went under truck between rear tire and bumper.he always checked it and had his seatbelt on but not that one time and its all it took.thank god it was only bruises
72 cheyenne 2wd lwb 71 k20 sons bassett va |
![]() Join Date: Nov 2002
Wow, 72shadetree, that was a close one! My drivers side door came open in a turn one day, but I was only a little embarassed - not nearly killed.
Therefore, I agree also. Get new door handle mechanisms. They are worth it. Jeff ![]()
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
1972 was the only year that the shaft was longer to fit the bigger plastic door panels.
