speedo cable
I just got a new cable for a K-20 from Brothers and there ain't no way it will reach the way the old one did. The original went up the firewall and tru to the inst. cluster. They insist it is the right one. I ambringing it up under the trans hump and then to the gage cluster. Thisworks. Anyone else know anything about this subject? any experiences?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Old member
Re: speedo cable
Take the one you just got and go to any parts store to match it up. I just bought a new one and it's about 12" longer than my stock 2 wheel drive was.
I bought mine at Auto Zone with the housing too!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: speedo cable
I spent my money with Brothers.......................live and learn. the 12 inch difference is what it needs!
Inline 69
Re: speedo cable
did you get the Item:# PLCBL01 ? its 68" long -will not work on 4x4
Re: speedo cable
i bought a universal replacement inner at o'reilys dirt cheap and works great
common sense isn't so common anymore |
Re: speedo cable
I have no idea what they sent. They insist that it is the right one for 4x4
Re: speedo cable
Oreillys, Under 20 Bucks With Housing And They Have All Lengths In Stock
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
