Keepin' It Stock
I agree w/ David and Paul on the door panels. I ordered a set from Chevy Duty and they WILL NOT WORK with the woodgrain inserts, plus the overall quality sucks. If you want to see how bad they are check out:
http://www.lunarpages.com/pattson/maych/mh_pro_4b.htm (If you can't veiw the site, try back later as they only allow me so much bandwidth per day) What I can't figure is, if the vendor knows they aren't going to work with the woodgrain inserts, why not say so in the catalog. By the time you figure out they won't work, you've already cut holes for the metal trim, so you can't return them - big $$$ wasted. VERY BAD FOR CUSTOMER RELATIONS. ------------------ 72 Sierra Grande - "Maych" If a man speaks in the middle of a forest and there is no woman around to hear him, is he still wrong? Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
| Bookmarks |
