Old 03-10-2008, 10:17 AM   #1
rick0312
rick0312's Avatar
Overhauled my drive shaft
Read farside847 tech post on how to overhaul a drive shaft. Very helpful! thanks farside847! Went pretty smooth except that NAPA sold me the wrong front U-joint(need to exchange for correct one). All new U-joints, carrier bearing and a bit of rust encapsulator The ball joint press really made things easy....Rick
rick0312 is offline   Reply With Quote
Old 03-10-2008, 11:04 AM   #2
mcc-bri
mcc-bri's Avatar
Re: Overhauled my drive shaft
you might want to reinforce that bearing carrier, they are a lot weaker then the originals and break (so i am told) without reinforcing them.
You should weld all the way around the seam on the top where it mounts to the frame, the two peices are only spot welded. Then you should take some band iron and weld it from the side of the mount, down and around the bearing housing part and up the other side. The guy who told me this hasnt broken one since he rienforced it.
Ill try to get a pic of mine up so you can get a better idea of what im talking about.
mcc-bri is offline   Reply With Quote
Old 03-10-2008, 06:10 PM   #3
truckdude239
truckdude239's Avatar
i installed a carrier in my drive shaft and it came from orielys it lasted 4 months before breaking got another one from advance lasted 3 months advance gave me another one i took the shields off this time and its been fine since
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-10-2008, 07:00 PM   #4
matthufham
i had to weld mine from oreily's, then that melted the rubber a little, and now the driveshaft drags on the rubber. i need to fix that
matthufham is offline   Reply With Quote
Old 03-10-2008, 08:44 PM   #5
rick0312
rick0312's Avatar
I am running a stock 260hp/350. does more h/p put more stress on the center bearing?
Old 03-11-2008, 01:43 AM   #6
rick0312
rick0312's Avatar
the front U-joint is way too big. I am running a 4 speed saginaw car tranny. Is the front U-joint the same size as the center and rear? I assume the joint NAPA gave me is for a truck tranny yoke.
Old 03-11-2008, 02:03 AM   #7
mcc-bri
mcc-bri's Avatar
Incase you didnt know you can push that rubber peice out that holds the bearing.
Old 03-11-2008, 02:21 AM   #8
rick0312
rick0312's Avatar
Yea I know that the bearings come off, even with them off I couldn't get the U-joint in.
Old 03-11-2008, 03:47 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
HP doesn't effect the bearing if everything is lined up properly.
I would take that to a drive shaft place and have them spin it, a mild off ballance condition may go unoticed, but could damage things like the rear diff and the brass bushing in the tailshaft of the tranny.
