Old 03-12-2008, 02:34 AM   #1
inspectorscott
Lift for 72 C10 2 Wheel Drive?
Hello All,
I have a 72 c10 2 wheel drive and would like to raise it so that I can run 31" tires. I do not care for body lifts and would like to do this all suspension. It is currently lowered with CPP spindles and springs. I have the rear coil suspension. Any suggestions? A quick search of the internet and this board gave me no results.
Thanks,
Scott
inspectorscott is offline   Reply With Quote
Old 03-12-2008, 02:50 AM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Lift for 72 C10 2 Wheel Drive?
Several companies make coil lift springs....about 2" springs should do it but that is about as far as you can go and still allign it.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-12-2008, 03:00 AM   #3
inspectorscott
I appreciate the response. Do you have the names of any of those companies?
Scott
Old 03-12-2008, 03:45 AM   #4
hotrodhomi
hotrodhomi's Avatar
I would sell it and buy a 4x4. There are much easier to lift with leaf springs.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-12-2008, 03:58 AM   #5
stepn67
Junior Member
stepn67's Avatar
Fabtech used to sell lifted spindles, springs and upper ball joint spacers for 73-87 trucks which worked on our trucks, but sad to say they no longer carry these. Your best bet would be to get a spring shop to build you a new spring with the lift you need (2 - 2.5" max). The upper ball joint spacer would also help alignment if you could have a machine shop mill a 2" billet spacer to fit between the ball joint and control arm.
stepn67 is offline   Reply With Quote
Old 03-12-2008, 06:25 AM   #6
wibilly
wibilly's Avatar
i have 31"tires on my 69 stock height plenty of clearance
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-12-2008, 06:36 AM   #7
stonewall618
Just loves his truck.
stonewall618's Avatar
im getting ready to put 31s on my truck all i did was get rims with a shorter back spacing and wider too...
Gold 1969 c10 LWB--350 gm crate motor 30"muds on the back...with aluminum rims with black and red Chevy bowtie center caps that look awesome!
EAGLE SCOUT FTW!!!
stonewall618 is offline   Reply With Quote
Old 03-12-2008, 06:47 AM   #8
tim21391
tim21391's Avatar
I am running 31's stock height....heres my combo...31x10.50r15LT
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-12-2008, 08:22 AM   #9
69halfton
69halfton's Avatar
i KNOW for sure i have at least 31's (PO installed them, im not a fan) and they might even be 33s, i do remember them being the same size as my buddy 79 4x4. stock height, no clearence issues.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-12-2008, 08:34 AM   #10
Shyguy
Junior Member
Shyguy's Avatar
My stock '71 C-10 has 30x9.5x15 on the front and the rear has 31x10.5x15.
Danny
Shyguy is offline   Reply With Quote
Old 03-12-2008, 07:26 PM   #11
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
stock height and running 31's on my 69
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-12-2008, 09:32 PM   #12
stonewall618
spring spacers?...OOO you could do wheel spacers check ebay
EAGLE SCOUT FTW!!!
