Need Help With Air Ride System!
Ok so I went to go get in the Binder the other day to drop the front and i hit the switch and nothing happen, so i went to lift it, and it went up but will not go down! I know nothing about bag sytems, there is a junction block inside the engine compartment, where the air line comes into, with two little black solinoid looking things that say mass magnet on them with a ground and a hot wire coming out of them. I figured one was to open the valve and one to close it or something?? and on one of them it looked like the ground wire got pulled out a little, most likely got stepped on while putting the motor in, so I switched the two "mass magnets" around to see if it would now go down but not up! but still did the same thing will go up but not down, I even changed switches to see if i just had a bad switch! what else could this be, do i have a stuck valve or something? It seems to be a very simple system, i have have two switches, one for the front and back up and down, and one to turn the compressor on and off! PLEASE HELP, I'LL POST PICS TODAY!
__________________ |
#2 | |
Re: Need Help With Air Ride System!
http://www.fbirides.com/product.asp?...icks&idno=8289 Last edited by PrerunnerRob; 03-13-2008 at 05:11 AM. |
Hollister, CA.
![]() Join Date: Sep 2006
Also...if you do in fact have the Blitz valves....they may also have an LED between the the terminals (used as a clamping diode)....Have some one hit the dump-switch, and check to see if there is power.
Be sure an stand clear, just in case. Try cracking the line to the bag...to relieve some pressure, then try again. If your running mulitiple batterys, try shoot'n 24v momentarily to the valve to see if it opens.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
![]() ![]() ![]() ![]() ![]() ![]() ![]() this is what im working on! I know its not a chevy but atleast its got a chevy power plant! ![]() |
thats cool, don't see to many internationals around here. that is what it is right?
yes its a 1974 international 100
#7 | |
Hollister, CA.
Cool look national...what's up with that smashed green wire ?? Is that the valve with the issue ?? ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-15-2008 at 05:36 PM. |
Sweet! Did this resolve the problem?
took off the plug you were talking about with the screw on top! and switched to the other one to see, if it was bad, and it did the same thing! i checked the plug and it didn't look pulled out it still had all three connections in there! im stumped, but that doesn't take much cuz i don't have too much experience with these, how much are those mass magnet things? i wouldn't even know where to find them?
#10 | |
If you need a valve and solenoid coil, you can get one here: http://www.fbirides.com/product.asp?idno=8289 Let me know how it goes! Last edited by PrerunnerRob; 03-15-2008 at 08:25 AM. |
yes it is! but i put this on the other valve and it didnt change the out come so i figured it was ok!
