still buypickupparts
when the factory installed A/C ?
because I dont know and the assembly manual does not show this either I jus need to ask. I am putting original factory a/c parts in my non a/c cab. ok my question is on the passenger side did the side air vent along the kick panel come installed if you had factory air?. I know there is a vacuum deal mounted on the air vent with a/c but was there both manual vent and the vacuum deal?
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
Re: when the factory installed A/C ?
With factory AC there was not a manual vent setup. The brackets mounted on the door for AC are different from the brackets that the manual vent used.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
454 MAKES IT ROAR
As far as i'm aware there was no manual operation of the passenger air vent, on my 71 with factory air I can see pre drilled holes to mount a lever but these would not be used on an A/C truck as the vacum actuator goes there instead.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
