Old 03-12-2008, 09:27 PM   #1
79GMC_OLDS
79GMC_OLDS's Avatar
changing 2 speed to delay wipers
I have the 2 speed wipers in my 79 and i was wondering if i could swap in the steering column with delay from my 86? do i need to change wiper motors or can i just wire the delay to the old motor?
thanks
79 GMC Sierra 5.9 cummins, nv4500
79GMC_OLDS is offline   Reply With Quote
Old 03-12-2008, 11:03 PM   #2
BowTieOgre
Re: changing 2 speed to delay wipers
Im not sure about the column swap but why dont you just buy an intermittent wiper switch/relay from the junkyard. It works great and plugs right in to the 2 spd. wiring plug. There is one on EBAY right now.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-12-2008, 11:50 PM   #3
Greenlee
Greenlee's Avatar
Does anyone happen to know if this would work on a 76'? The guy selling the switch on Ebay says 78' to 83'.
Greenlee is offline   Reply With Quote
Old 03-13-2008, 12:09 AM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I've got the switch and module on my 81 crew. I'll get pics of it tonight and post them on here so's you can see what the connections look like. If they are the same as your '7 model then they should work. Otherwise you'd have to do a slice-n-splice.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-13-2008, 07:11 AM   #5
79GMC_OLDS
79GMC_OLDS's Avatar
ok awesome thanks...so if i wanted column mounted controls i could just wire the delay into the original wiper motor? in other words the motor has nothing to do with the delay
Old 03-13-2008, 07:36 AM   #6
BowTieOgre
Yeah the delay part is handled by a part that goes between the switch and the factory plug...nothing to do with the motor.
Old 03-13-2008, 07:40 AM   #7
BowTieOgre
I think the wiring is the same (but I would be incorrect, see below) but the mounting points for the switch are different. Take a look at the LMC catalog.
Sorry for the multiple posts mods.
Old 03-13-2008, 05:22 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
Actually...the 77 and down wiper motors are quite different from the 78-83 motors. I tried to put a 78-83 motor on a 77 and it wouldn't work. The connectors don't match up, and there aren't even enough wires. Same on the switch side, the 77 connector is incompatible with the 78-83 switch.
In order to perform the swap, I had to remove all the wiring from the 78 and transfer it to the fuse box of the 77. Also had to enlarge the switch hole in the dash and drill new mounting holes.
Pyrotechnic is offline   Reply With Quote
Old 03-13-2008, 08:26 PM   #9
Tink
Tink's Avatar
This guy put delay wipers in his 75 Burban and has some great info:
http://www.rowand.net/Shop/Tech/DelayWipers.htm
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
