Old 03-07-2008, 03:03 AM   #1
1985K10
1985K10's Avatar
12 bolt question
Im about to rebuild the 12 bolt in my 77GMC(1/2ton 4x4) which has just an open diff, and I have a 12bolt from a 73-77ish 2wd that is limited slip.
Can I put the limited slip in the 4x4 rear?
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 03-07-2008, 03:20 AM   #2
Jonboy
Slots go on anything!
Re: 12 bolt question
You should be able to. I think the only difference is the axle shafts and brake drums.
Jonboy is offline   Reply With Quote
Old 03-07-2008, 03:25 AM   #3
454HO
If it is a Gov-Loc differential, I would not bother with swapping. From what I understand, they are very weak.
- Greg
454HO is offline   Reply With Quote
Old 03-07-2008, 08:47 AM   #4
1985K10
1985K10's Avatar
Ill pop it open and check it out when a little bit more snow melts off it!
Thanks!
Anthony
07 Tahoe LT
Old 03-07-2008, 07:41 PM   #5
James McClure
One shot, one kill.
1985:
I'm not saying anything against 454 here OK? I run a "detroit locker" in my truck without any problem at all and the truck has over 400,000 miles on it. I spent over 30 years working for GM in "farm country" and have only had to rebuild 3 of them due to a failure of the locking mechanism. I will say this though, you will not be able to rebuild a locker at home if you blow it up and the parts aren't cheap. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-14-2008, 07:48 AM   #6
1985K10
1985K10's Avatar
I opened the 2wd 12 bolt tonight, it has the clutch type limited slip, 34ring-10pinion, or 3.40 gears.
I opened the 4x4 12 bolt im using, it was 43-14, or 3.07 gears.
Can I remove the carrier, swap ring gears, and put it in the 4x4 rear? Or will I have to setup the ring and pinion clearance again?
Anthony
07 Tahoe LT
Old 03-14-2008, 07:54 AM   #7
bagged01extcab
You will have to set up R&P clearance again.
Trey Oney
bagged01extcab is offline   Reply With Quote
Old 03-14-2008, 02:29 PM   #8
James McClure
One shot, one kill.
1985: bagged MAY be right. Swap out ring and pinion (with new crush collar) and make your measurements. If clearence is under .002" you should be ok. Test drive for noise (whine). If it's noisy you will have to take it in to GM and get them to measure pinion depth. Chances are you'll be fine. In the 33 years I did mechanical work I never had to change the pinion depth shim dimention. I've had to replace shims but always used the origional dimention. jim
