Old 01-20-2003, 06:09 PM   #1
69ChevySB
dropped69
Coil Springs Question
Hi there again folks, could someone here please tell me if some stock coil springs from a 69-70 3/4 ton c20 would fit on my 69 c10? my neighbor across the street has a 72 c10 and he said that his coil springs were 3/4 ton coil springs...so I shouldn't have any problems switching the ones from the 3/4 ton to my 1/2 would i? also whats the difference between the 1/2 and 3/4? does it make the truck look any different than if it had 1/2 coil springs? thanks
69ChevySB is offline   Reply With Quote
Old 01-20-2003, 09:06 PM   #2
CustomChevy
Should ne no problem, the spring rate is what changes, the coils themselves will only increase slightly in diameter. Overall, they should fit just fine.
good luck!
CustomChevy is offline   Reply With Quote
Old 01-22-2003, 11:39 PM   #3
rustedchevy
will fit and work, yes, the weight rating of them isnt hugely different from 1/2 ton to 3/4 ton, would have to look in specs sheets again to be specific, can use 64-87 coils
rustedchevy is offline   Reply With Quote
