Dropped Spindles? How do I tell.......
My truck was lowered somewhat by the original owner and I think he heated the coils, but he could have added lowered spindles. How do I tell if the spindles are dropped or not? What do I measure? Thanks!
Brave Dave
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible |
Cantankerous Geezer
What you need to measure is the distance from the lower a-frame to the spindle. Easiest would be from the center of the spindle to the ground, then subract the distance from the ground to the bottom of the a-frame at the ball joint. then find another truck without drops and compare.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
One way to tell is the lowered spindle will be about half way up, or centered, on the spindle. The stock height spindles are toward the end. Early Classic Enterprises' website has pictures of them so you can see what I'm telling you about. I'm betting if the actual spindle is half way up, they're lowered. check out http://www.earlyclassic.com/catalogpg11.html for photos of the spindles.
Hope it helps ya out.. Riley
72 Chevy short stepside 350/350 tilt, vintage air a/c sunset Orange Metallic paint Early Classic 2.5/4 drop eagle series 211 wheels |
Thanks for the link, Riles.... I know just what to look for now. The comparison photo was just what i needed!
