Engine stand bolts
What size,length and grade of bolts would you use for a engine stand? Its the 1000 pound version from harbor freight.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Engine stand bolts
I would definitely use grade 8. I used shoulder bolts that have a larger diameter than the threaded end so it would be a better fit going through the
round mounting points. I hope I explanned that ok. |
ehhh... 4 grade 5 bolts have enough sheer strength to hold your engine, but use grade 8 if you have 'em. I just so happened to have some Caterpillar grade 10.9's that fit my stand perfectly!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
The cost difference between grade 8 and 5 is far less than the cost of a new foot.
The bolts should thread in as far as they can without bottoming, and/or as far in as the original bolts used in the holes. Maybe those were dumb answers... |
