Old 03-11-2008, 03:54 AM   #1
meathead95
computer illiterate
meathead95's Avatar
please help me id these casting numbers
engine.. 358180 T0518HCR
intake... 3344459
crank... 1178
Trans... T10-1B, Wg div Q-2 T10-K7 H2-71
thanks
keith
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 03-11-2008, 05:35 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: please help me id these casting numbers
For the engine I got:
T= Tonawanda plant
05= May
18= 18th
HCR= 1966 327 275HP 4 bbl Powerglide Rochester carb.
Someone please correct me if I'm mistaken. Haven't found anything on the other stuff yet.
Also, are you sure the number isn't 3858180?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-11-2008, 06:04 AM   #3
meathead95
computer illiterate
meathead95's Avatar
im sorry you are right it is 3858180 i had a dumb ass attack. i double checked all the other numbers listed and they are correct. thanks for what you found so far
72 2wd blazer
72 swb 4x4
Old 03-11-2008, 06:34 AM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
64-67 327 small journal car or truck.
Intake: How about 3844459? 63-65 cast iron 4 bbl carter afb.
My book doesn't break it down anymore.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-11-2008, 06:42 AM   #5
chevy one
Chevy One
Mortec list the crank as; 1178.......302.......forged..medium journal...3.00stroke"
Chevy One
67 1/2 Two-on-the-Floor
67 Nova 2Dr Sedan
03 Monte Carlo
I'M NOT OLD, JUST A CLASSIC!!!
chevy one is offline   Reply With Quote
Old 03-11-2008, 07:02 AM   #6
meathead95
computer illiterate
meathead95's Avatar
thats right thanks. lol...........
72 2wd blazer
72 swb 4x4
Old 03-11-2008, 07:11 AM   #7
meathead95
computer illiterate
meathead95's Avatar
i found this for the trans the numbers on it are real close
Dave, What you have is a 1st design Super T-10 which was only available as an over-the-counter complete transmission designed as a direct replacement for the early Corvette T-10. They were made from 1968 through early 1972 and did have 10-spline input and 27-spline outputs like the early T-10 and early Muncies. There were several gearsets available for them including 2.23:1, 2.43:1, 2.64:1 and 3.44:1 first gear ratios. Some even had 9310 nickel inputs (with 0.060" wider gear) and clusters installed (Also had a 0.060" wider front gear to mate with the wider input) which had much higher torque capacity. Later 2nd design ST-10's all had 26-spline input and 32-spline outputs like the 71-74 Muncies.
All in all, a good transmission. The only weak point is they have a tendency to seize first gear to the mainshaft. There is no sleeve on the mainshaft for 1st gear like Muncies and ST-10's.
72 2wd blazer
72 swb 4x4
Old 03-11-2008, 10:44 PM   #8
meathead95
computer illiterate
meathead95's Avatar
anyone else? can anyone verify the trans numbers?
72 2wd blazer
72 swb 4x4
Old 03-19-2008, 01:01 AM   #9
meathead95
computer illiterate
meathead95's Avatar
can anyone id this saginaw 4spd for me
gm8281886
3925656
Nfc2 8114
72 2wd blazer
72 swb 4x4
Old 03-19-2008, 01:11 AM   #10
larry may
gm8281886
3925656
Nfc2 8114
1970-1972 Camaro Transmission
http://www.nastyz28.com/2gcog/trans.html
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 03-19-2008, 02:02 AM   #11
meathead95
computer illiterate
meathead95's Avatar
cool thanks
72 2wd blazer
72 swb 4x4
