Old 03-19-2008, 09:24 AM   #1
Down south truckin
Down south truckin's Avatar
??Questions about Original 4 speed shifters??
Ok I've been hankering to build a 71-72 4x4 4 speed one ton for a while now and have been rounding up parts lately and was wondering if any body knew how many different shifters came on these trucks and which one fits which I just bought 3 different ones from Teeitup and he said they all came off 67-72 I know I've seen 4 speed humps with the shifter hole way up front and the 4x4 ones were kinda in the middle and was wondering if one of the shifters would have been longer to compensate for this? I have a 1/2 ton 4x4 4 speed truck but I'm pretty sure it has a later model shifter in it because it has 2 bends like the one on the right in the picture.any knowledge shared would be greatly appreciated thanks Mike
Down south truckin is offline   Reply With Quote
Old 03-19-2008, 09:57 AM   #2
CRUE's 67 LWB
Re: ??Questions about Original 4 speed shifters??
The first shifter handle is for a NP205 I believe.
Iam not sure of the rest but it probably depends on the trans transfer case combo for the pull back of the shifter handle.
CRUE's 67 LWB is offline   Reply With Quote
Old 03-19-2008, 02:07 PM   #3
That 1st trans shifter is the correct shifter for a 4wd.At least it is for the SM465/NP205(`70-up).The other two must be for 2wd since they are so much longer.
Old 03-19-2008, 06:25 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
i agree with Tim on this one. if my memory serves me correctly the 2wd shifters were longer and had an extra bend because the shift tower was closer to the dash. not sure if a big block/4 speed shifter was different than a small block/4 speed shifter or not. i've only owned one big block/4 speed truck and that was a LONG time ago.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-19-2008, 07:54 PM   #5
1969k10stepside
My sm465 shifter in my 69 K20 (Sm465/Rockwell t221 t-case) looks like the second shifter with the first being a 71-72 np205 shifter.The one farthest right looks like the shifter for my sm465 in my 84 c20 with a 454/465.
1969k10stepside is offline   Reply With Quote
Old 03-19-2008, 08:33 PM   #6
Ace in the hole
Well that's just great. It looks like I may need to find a 4wd shifter now too. My 465 came out of a 2wd and it's shifter looks like the one farthest right. I am working on my cab and don't have it on the frame so I can't tell if my shifter will work or not. I guess I'll have to wait and see.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 03-19-2008, 09:00 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Don't know if this will help or not or how accurate it is but it's interesting none the less....
LockDoc
Leon
Old 03-19-2008, 11:01 PM   #8
drivethechevy
drivethechevy's Avatar
im sure locdocs diagram will help u plenty but i thought id just confirm that the 2 long shaft ****ers are for 2 wheel drive pickups i have a few different 2wd that have one or the other of those shifter and the dual bend shifter is just like the one i have in my 71 blazer 4x4,
since on the topic does anyone know about a stock 5 speed as an option in a 72 1ton flatbed cause im looking into a purchase on this truck and from what the owner told me its all original down to the 5 speed hd tansmission and ive never heard of any stock 5 speeds in any 67-72 1 tons anyone know anything about this im thinking it was added but i havent crawled uner to see if i can tell if its been added and the glovebox door is long gone
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 03-20-2008, 12:22 AM   #9
tkeduk8r
tkeduk8r's Avatar
I will alos confirm the longer shifter with the bends is for a 2WD truck and the short shifter is 4WD. Ihave my 68 2wd dump parked next two my 70 K10 and compared the shifters one day... about the 5 speed thing....
a few old timers told me about a 5 speed trans out of a C50-80 trucks that can be swapped in place of a 465 pretty easily and was done quite frequently back in the day.... It is NOT an OD trans but you essentially got an extra granny gear in the 7.00 range for a little extra grunt pulling out... the pattern for this trans is somehting like this... a board member here uses it in their avatar IIRC...
1-2-4-R
3-5
Hope that aids to the confusion!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 03-20-2008, 05:24 AM   #10
Down south truckin
Thanks for everyones input! do yall think the one on the far right in the pic is the same as the 73-87s??
Old 03-20-2008, 05:35 AM   #11
1969k10stepside
Mike if it quits raining here (already got 2" of rain,and 2-3" more expected!) I'll check and see if the shifter in the 84 looks the same.BTW,hows the most recent 4wd project going?
Old 03-20-2008, 05:43 AM   #12
Down south truckin
Dustin, I have been busy with alot of stuff going on lately but I actually dropped it off at my buddies house over the weekend He's been out of work and offered me a deal that I could'nt refuse hopefully it will be taking shape this weekend and I'll update my thread thanks Mike
Old 03-20-2008, 08:38 AM   #13
dan42
dan42's Avatar
Mine looks like the second one, but it hits the dash in third. I have a 2WD '67 with the SM465. I would prefer to find a double bender if I can, but I'll probably just make the one I have into a double-bender.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-20-2008, 03:14 PM   #14
It looks like the 435 shifter to me.It`s hard to tell if there`s an offset to the side or not.
Old 03-20-2008, 03:40 PM   #15
Ace in the hole
Hey dan42, how about a trade for my 2wd version? I'll PM you. Before this thread came along I was not even aware there were 2 different shifters.
Old 03-20-2008, 04:32 PM   #16
teeitup
Just like to part out trucks!!
teeitup's Avatar
The green ended one came out of a 67 1 ton, one of the other 2 on the right came out of a 72 1 ton longhorn, (not sure which one though and not sure what the other one came out of) The 205 shifter came out of my 72 4x4.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-20-2008, 04:40 PM   #17
72gord
Never enough time!!
72gord's Avatar
Guys, if length isn't a problem and your not using a chrome shifter, just put a little heat on it and bend it how you need it, then paint it.....unless your going for strictly OEM. I have bent a couple of them in previous projects, no problems at all.
72gord is offline   Reply With Quote
