Old 03-17-2008, 07:43 AM   #1
andys70c10
help! truck backfired & stalled
See if you mechanics could help me here, I was driving home tonight, the truck was running fine well I'm almost home & the truck starts slowing down so I pushed the gas pedal & the truck backfired about 2 times, luckily I was almost home & it coasted in the driveway, now it just turns over & every once in awhile acts like it wants to crank. The truck has a 350 crate motor with a 2bbl. it has also been converted to hei. Any thougts & how do I check for spark etc?
andys70c10 is offline   Reply With Quote
Old 03-17-2008, 07:52 AM   #2
berencam
berencam's Avatar
Re: help! truck backfired & stalled
you can buy a spark checker at any parts store, sounds kinda like a stuck float on the carb to me...
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 03-17-2008, 08:15 AM   #3
cdowns
cdowns's Avatar
to check for spark take a plug out put it on exhaust or intake manifold and turn motor over// how old is the timing chain?
Old 03-18-2008, 04:52 AM   #4
andys70c10
motor probably only has about 20,000 miles on it, my dad thinks its the ignition module in the distributor? I'm about to check for spark now
Old 03-18-2008, 05:08 AM   #5
andys70c10
ok i pulled a plug & grounded it to the motor & I see no spark, so it probably is the module right? my dad says its a pita because you have to pull the distributor, how about some help here guys. at least give me more responses than somebody wanting to know about a ford 352.
Old 03-18-2008, 05:18 AM   #6
89 crew
You don't have to pull the distributer for a module. You do have to pull it for the pickup coil. I would start with the module. take it to an auto parts store and have it tested.
89 crew is offline   Reply With Quote
Old 03-18-2008, 05:25 AM   #7
andys70c10
ok dumb ? where is the module & how do I get to it? also a pic would help. Thanks
Old 03-18-2008, 05:53 AM   #8
cdowns
cdowns's Avatar
before taking out module check that the supply wire to it is a live 12volts because it wont work with no power to it
Old 03-18-2008, 07:39 AM   #9
89 crew
The module is located under the distributer cap. It looks like the one in this link. http://www.autozone.com/selectedZip,.../selectZip.htm
While you have the cap open, check the rotor ( be sure to check the bottom side for arching to the center shaft), cap, and the button under the coil.
Old 03-18-2008, 07:46 AM   #10
70c10
67-72 Addict!
70c10's Avatar
This might be the problem! On the drivers side of the HEI (along the bottom edge of the housing) you have a tach terminal and a Bat terminal. Make sure your connector for the bat didn't pop off or come loose!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
Old 03-18-2008, 06:26 PM   #11
andys70c10
I am going to check my power wire, but I believe instead of changing parts in th dist. I am going to buy me one of those $45 distributors off ebay & replace the whole thing.
Old 03-18-2008, 06:49 PM   #12
89 crew
There is no guarantee that the distributer is the problem. That is the reason I was reccomending testing parts. By the original description it could be a fuel problem and the plug just wasn't grounding when you tested for spark. I hate to throw parts at a truck cause I don't know what the problem is. I don't mind testing parts to verify a problem.
Old 03-19-2008, 03:57 PM   #13
andys70c10
well I pulled the plug out & grounded it, but then the haynes manual said to just pull a wire off & hold it about 1/4'' off something metal & it would spark, I tried that to & nothing. I also checked & have 12v going to the dist. & had my old module tested & it tested ok. The inside of my old dist. looks a little iffy, there is actually some frayed wiring going to the module plug, so I,m pretty sure thats it but even if not it can't hurt.
Old 03-19-2008, 06:23 PM   #14
68gmsee
Active Member
68gmsee's Avatar
My old 69 Chevy had a problem HEI distributor that did the same. It would act up and I never found out what the problem was. I went to a junkyard and got one for $20. That was about 10 yrs ago. Still doing good.
Good luck and let us know what you find..
68gmsee is offline   Reply With Quote
Old 03-20-2008, 06:23 PM   #15
89 crew
Where the module is good I am going to guess those frayed wires you saw go to the pickup coil. There is a procedure to test a pickup coil, Don't remember the ohm range for good and bad right now. but if it is bad it can cause all sorts of problems including no start. You have to pull the distributer to work on it.
Old 03-20-2008, 07:16 PM   #16
andys70c10
yes the haynes manual tells you how, I also tested my coil & it is good also, like i said if I'm going to pull the dist. anyway & mine looks kinda raggedy in there, i am ordering 1 from skip white on ebay. Thanks for everybodys help
