Old 03-19-2008, 11:55 PM   #1
coggonobrien
4x4 frame interchangeability between 67-72 & 73 up
Hello I am getting geared up to build a Chevy 4x4 and had a question
pertaining to chassis interchangeability. I have been offered a dirt
cheap 1975 4x4 manual to be used in my 1969 truck project. basically
i can get the 2wd 69 for cheap as well but ideally want to build a 4x4
to be used as a farm truck. I know the crossmembers will all be in
the wrong places but I am under the impression that the 69 box will
bolt directly to the 75 frame. then all the cab mounts, radiator core
supports, bumper mounts, etc will have to be custom mounted. Is there
any truth to this and has anyone done it? thanks, Dave
coggonobrien is offline   Reply With Quote
Old 03-20-2008, 12:47 AM   #2
1972Ryan
Re: 4x4 frame interchangeability between 67-72 & 73 up
I'd like to know also.
1972Ryan is offline   Reply With Quote
Old 03-20-2008, 02:54 AM   #3
1969k10stepside
The whole chassis is designed different pretty much.It's longer and is shaped alot different than a 67-72 frame.You will most likely need a body lift,shorten the chassis or deal with a gap between the cab and bed,plus all the mounts for the body to deal with.I'd go for converting the 2wd to 4wd using the springs,axles,tranny,t-case,etc,etc on the 67-72 chassis before going to the trouble of using a 73-87 chassis.People convert 4wd blazers to 2wd everday,don't know what you can't do the opposit.Mudder put a 67 body on a newer chassis,you might ask him
1969k10stepside is offline   Reply With Quote
Old 03-20-2008, 04:14 AM   #4
coggonobrien
interesting. so in ur opinion just move the entire drivetrain/suspension to the older frame?
Old 03-20-2008, 04:17 AM   #5
coggonobrien
or i guess rather use the drivetrain and probably get a lift kit for the 69 frame and bolt those springs to the newer drive train?
Old 03-20-2008, 05:12 AM   #6
ed2552
ed2552's Avatar
i have a 67 K10 long bed that needs some work.
edited......... Ed you need to subscribe to sell parts here on the boards.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-20-2008, 05:20 AM   #7
ed2552
ed2552's Avatar
Where in Iowa is Coggon? Northern or southern? How far from the MN border?
Old 03-20-2008, 07:17 AM   #8
FormerMember
There are vendors out there that have a 2WD to 4WD conversion kit... you could use the drive line from the later model to do it.
(I did it)
FormerMember is offline   Reply With Quote
Old 03-22-2008, 12:43 AM   #9
duallyjams
duallyjams's Avatar
A 2 wheel frame and a 4x4 frame are totality different.Swapping would be harder than going with a 69 on a 75 frame. I believe that Mudder has a right up on how to do it and oldblue60 has a truck that the same thing was done.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-22-2008, 12:46 AM   #10
FormerMember
I am not sure what you're saying here.
I have done the 2 to 4wd swap. It used to be pretty hard, but the brackets are available. They're really not that different. See the C to K conversion thread linked in my signature.
I have also done the body swaps, which was far tougher.
Add in swapping drive train and I am not sure.
Old 03-22-2008, 03:34 AM   #11
duallyjams
duallyjams's Avatar
That would make you the MAN.
James
IG duallyjams
Old 03-22-2008, 03:38 AM   #12
FormerMember
Heh, no that would make me ADDICTED.
These make it easy:
Old 03-22-2008, 04:07 AM   #13
duallyjams
duallyjams's Avatar
What a great addiction.
James
IG duallyjams
