Old 03-16-2008, 11:50 PM   #1
Highsteel
Chasin' the Dream
Highsteel's Avatar
Arrow Mystery Wires
Was poking around under the hood the other day and ran across this loom that I can't find a component for(can't find anything not hooked up). Anyone have any ideas.
I attached a couple photos(not the best, sorry) of the loom and the connectors(lying on the inner fender).
71 C/10
350/TH350
Last edited by Highsteel; 03-17-2008 at 08:01 PM. Reason: Better Photo of wire ends
Highsteel is offline   Reply With Quote
Old 03-17-2008, 12:24 AM   #2
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Mystery Wires
Oops, wrong thread.
Shoulda went in pick-ups, sorry.
Peace
Out
Old 03-17-2008, 08:00 AM   #3
uncle
Re: Mystery Wires
They are both trans. related.
uncle is offline   Reply With Quote
Old 03-17-2008, 08:25 AM   #4
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Mystery Wires
Really. Maybe on the modulator on a TH350? Not much of an automatic mechanic.Could this degrade performance? I mean it shifts and all, but it does seem kinda soft and mushy, unless I've just had a standard for too long.
Highsteel
Peace
Out
Old 03-17-2008, 10:10 AM   #5
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Re: Mystery Wires
I will move this over to the pickup forum for you. Good luck.
oldiron is offline   Reply With Quote
Old 03-17-2008, 03:56 PM   #6
OhioDan
OhioDan's Avatar
Re: Mystery Wires
Those look like alternater wires for a passenger side, internally regulated alt? Just my guess?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 03-17-2008, 06:08 PM   #7
short step
Re: Mystery Wires
cant see the colors but alt wires would be my guess.
bob
short step is offline   Reply With Quote
Old 03-17-2008, 08:08 PM   #8
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Mystery Wires
Thanks for that, oldiron. Will try and be more observant in the future.
Peace
Out
Old 03-17-2008, 10:14 PM   #9
Americanrider
Re: Mystery Wires
bob
Thats my guess too, looks like a alt loom. Some of the 73 & up motors had the alt on the pass side. Where is yours mounted now Highsteel?
Americanrider is offline   Reply With Quote
Old 03-17-2008, 10:17 PM   #10
uno67
uno67's Avatar
Re: Mystery Wires
one looks to be for the alternator the other i'm thinking your truck might of been a 4spd originally and thats the goes to the backup switch in the trans
uno67 is offline   Reply With Quote
Old 03-18-2008, 06:09 AM   #11
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Mystery Wires
The Alt. is located on the drivers side. I'm afraid the pic is a little deceiving. While the one boot looks like the lug cover for the back of the alt it actually contains two female spade receptacles positioned at a 90 degree angle thusly |_. The other accepts two male spades side by side (- -). There is also I believe to be a single ground wire.
Back-up lights would be a very good possibility except they work and the sticker in the glove box says TH350 from the factory(correct vin #)
The truck does have a K & H trailer brake controller and its condition is unknown.
I don't recall if there are wires going to the trany. All my work down there so far has been rear seal replacement in the trans. Didn't get very far forward from there.
Peace
Out
High
Last edited by Highsteel; 03-18-2008 at 06:16 AM. Reason: Add wire end descriptions
Old 03-18-2008, 08:23 AM   #12
ChevyC102007
ChevyC102007's Avatar
Re: Mystery Wires
I found those wires while hooking up the new alternator after someone stole the other one. The wires were bundled up and tucked into the driver side fenderwell next to the firewall. My friend that helped me reinstall everything hooked it up to the alt, charges just fine, (dont hurt either to have a 1000 CA battery either) and that was back in December of last year, so I believe that they are in fact altenator wiring for an internal regulated alt. Well the side by side terminal plug at least. I ll be damned If I can tell ya what the other is for.
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 03-18-2008, 08:54 AM   #13
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Mystery Wires
internal regulated alt. seems to be the popular consensus.
DUH! The thing does in fact have a new alt/EXTERNAL regulator.
Sorry to here that you lost one due to theft. Have you installed a hood release in the cab or hood lock of some kind? I have seen some in pics here(in-cab release) and thought it a pretty good idea, along with something to prevent starting.
Considering all the thefts this might be a good thread to start.
It could have instructionals for dizzy disablers, battery cut-offs,..........
Peace
Out
Old 03-18-2008, 08:54 AM   #14
cflvulcan
cflvulcan's Avatar
Re: Mystery Wires
antenna, a/c compressor??
cflvulcan is offline   Reply With Quote
Old 03-18-2008, 09:39 AM   #15
ERASER5
ERASER5's Avatar
Re: Mystery Wires
TSC :Transmission Spark Control. Early smog stuff. The flat plug use to go to a vaccum switch close to the carb. The "ground" wire went to a temp switch in the passenger side head. The last plug went to a switch on the tranny just above the cooling lines. Somewhere, there used to be a relay also. All these wires combined to kill the vaccum advance on the dizzy if the engine was cold (below 32°F) or the tranny was not in 3rd gear.
I removed mine completely and gave the temp switch to a member that was doing a complete factory rebuild.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-18-2008, 10:19 AM   #16
BurnoutNova
BurnoutNova's Avatar
Re: Mystery Wires
exactly right... this same thing had me stumped when i saw the pessure switch on a all original bone stock 70 CST Blazer, with a th350... i thought it was a kickdown switch or somthing at first
BurnoutNova is offline   Reply With Quote
Old 03-18-2008, 10:33 AM   #17
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Mystery Wires
For historical record,here's the schematics for this TCS system for 1970 Chevy/GMC;
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-22-2008, 05:00 AM   #18
ChevyC102007
Re: Mystery Wires
Peace
Out
Not as of yet, when we reinstalled the Alt we put it on the passenger side of the truck using the side by side female connecter. I dunno, mihgt be why the trucks shocking me sometimes when I get out of it (Guess thatll teach me). Wiring adapter is in the works.
[Cherokee saying]
