02-22-2008, 07:41 AM | #51 |
1972 Chevrolet SWB
Re: Project Big Brother!
I think if anything the axle would need to be moved forward of its original opening when using a stock short bed. I think that moving the axle forward will take away some of the "lengthy look" of the wheel base but still have the overhang in the rear to make it look right.
Im anxious as hell to see some renderings.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-22-2008, 12:05 PM | #52 |
i think itll look good moving the rear axle forward. the nissan ext cab pickups are like that versus the reg cab ones and it looks good. i think you should suicide the rear doors too, i havent seen that done yet...
02-23-2008, 02:15 AM | #53 |
Man oh man, I can't wait to watch another of your projects - they generally are what dreams are made of!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-23-2008, 06:44 AM | #54 |
GEARHEAD
Moving the rear axle further back is the current norm. Adds stability for towing and is a more comfortable ride. Look at any of the current long beds and you'll see the length behind the wheel well is pretty much the same as a short bed. Personally, I think the new long beds with the wheel well further back looks funny, but it's functional. In your case though, I know the long bed is not an option. But I think you would be making a mistake moving the axle forward, both from asthetics and design.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
02-23-2008, 07:51 AM | #55 |
Well lets not get to far ahead of our selfs as rear axel placment is along ways off. Once the cab if done I will take a set of step side fenders and section them so they just cover the rear tires, then I will clamp them to a long bed and start moving them forward and back to see how it looks. Once I find a good starting point for what I am looking for then I wil start shortening the bed until it looks right to me and my wife. Not that I do not like all the help from the board members but I am building it and she is not giving mne slack for doing it. Also I have found over the years her eye is dead on when it comes to the right perportions on vehicals. Their have been several builds were I sketch it out only to have her cut it up and change things on it. The worst part is she has always been right so far.
I have a way that I will be sectioning the bed that will only leave one weld seam per side no matter what I do to it so adjustment will be easy. All this is still a ways off as my curent project Trazer needs my full attention until it is done then I can start working on the crew cab between other projects. I also like the suicide idea problem is one of the big reasons for this build right now is to get things ready for two other customer builds that are going this way. So I really need to do this one with 4 regular doors for mock up and templetes for the other builds. Trust me doing the suicide route without a B pillar would be alot easier to pull off and I still will keep it as an option if I can get the 2 customers to go that way as well Keep in mind with the axel placement that it will have alot to do with the step side fenders and how close they can get to the bed corners. I will not shorten the fenders and do not want them right up to the corners of the fleet side bed, I think that would look funny. I hope to have enought time in the next month to get most of trazer finished up but if it takes more than so be it. Kevin LFD Inc. Last edited by Rokcrln; 02-24-2008 at 04:08 AM. |
02-23-2008, 10:33 PM | #56 |
mspaint (if you dont have photoshop) is your best friend for figuring out proportions. No cutting or welding required
02-24-2008, 04:07 AM | #57 | |
Here is one I just saw in another thread. Make it a crew cab 4dr and we are almost their once it gets an altitude adjustment! and a rear shot of another Kevin LFD Inc. Last edited by Rokcrln; 02-24-2008 at 07:05 AM. |
02-24-2008, 09:06 AM | #58 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-24-2008 at 11:34 AM. |
02-24-2008, 10:39 AM | #59 |
I had not picked up on that so far. Thanks for pointing it out
Do you have a shot of yours from the back showing how wide it is with your fenders on? Kevin LFD inc. |
02-24-2008, 11:32 AM | #60 |
I have a couple of direct rear shots, but they do not really show the width. I added a few more at slight angles to try to show how they really look. I cut 3" off of the stepside fenders and the outside of the tire sits about 1" inward from outside of wheelwell. I used a 14 bolt rearend out a '97 C3500 dually pickup. You may already know this, but the cab and chassis rearends are narrower, and you would have to run spacers to get the width of dually pickup rearend. If you build one without the wide rearend, you will have tub the inner fenders. Mine measures 92" across from the outside of the outer tires. Rearends out some cube vans, box trucks, and short buses are wide like the dually pickup rearends as well.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-24-2008, 11:44 AM | #61 |
BTW, another cool thing I discovered doing mine is that the stepside fender actually tapers down in the rear like the body seam does on the fleetsides. I never realized it before I did my dually, but you can see in the third pic even still mounted on the stepside box. If you take closer look at the baby blue truck and the red truck with sectioned fenders, the flares round down on the front and the rear and the top of the flare looks kinda domed shaped, which also takes away from the look of it IMO.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-26-2008 at 08:29 AM. |
02-24-2008, 05:22 PM | #62 |
Camaro Club
this is gonna be a sweet project. The thing i noticed though is that only you can have three pages on a project you havent even started yet. haha
02-25-2008, 09:44 PM | #63 |
Here's some good photoshop-able side shots of short SWB crew cabs that you could have the photoshop guys add some flares to.
02-27-2008, 08:21 AM | #64 |
Since the rear shots actually look like the tires are way recessed, I took these for you today to show the where the tires actually sit in the flares.
02-27-2008, 04:42 PM | #65 | |
Kevin LFD Inc. |
02-27-2008, 05:19 PM | #66 |
You're right. These stepside fenders make you choose between putting them on dead up straight and having the body line be perfect, or putting them on where the wheelwell rolls down like the front. When they are on completely straight up, the wheel well does not roll or wrap downwards like the the wheelwells do on the fleetside bed. If you look at the lowered white truck above, they are on more straight up than most, and the outside of the wheelwell is straight up as a board. I don't have the braces on mine yet either and I'm going to try to tweak it in a better when I get them fabricated. I think I can put a little pressure on the bottom of the fleetside bedside and move them out a little since they are so floppy now that the fleetside wheelwell is cut off.
03-01-2008, 08:02 AM | #67 |
PROJECT 7DEUCE
Looks like its gona be a killer project... But that light blue one has the best rear fender treatment I have seen. Look at the white one it looks like square fenders were added to the bed..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-01-2008, 09:19 AM | #68 | |
Also check out what one of my customers/firends (Project Trazer) gave me today! A set of front and back alcoa's with lugs and caps! Now I need to get his rig done so I can start this one one day comming up. Kevin LFD Inc. |
03-01-2008, 11:15 AM | #69 | |
Restoring a 68 SWB
03-01-2008, 09:33 PM | #70 |
2wd FTW!!!!
Sweet I Like The Wheels
03-13-2008, 04:33 AM | #71 |
I got to really looking closer at my rear fenders and noticed that they seemed to be angled down more than the were when I cut them, and I figured out why. Is was the fact that the wheelwell has been cut off the fleetside bedsides, the weight of the stepside fenders were making the whole panel droop down. I got out there today and added some support like what was on there from the factory and got everything straightened back up. It looks much better.
03-13-2008, 06:10 AM | #72 |
Yes that looks much better, nice job!
Kevin LFD Inc. |
03-13-2008, 09:57 PM | #73 | |
Restoring a 68 SWB
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
03-22-2008, 10:38 PM | #74 |
If not a diesel, why not a Caddy motor?
I have one pushing more hp and more torque than the Cummins in my 2005 Dodge Ram on gas, which is now cheaper then diesel. It's also slightly heavier than a SBC :p This is a nice thread for me, since I am building a dually K45 (C50 frame converted to K, with a 2.5 ton rear and a 1.25ton front) :p I've been waffling over an 8ft bed with step side fenders or a custom tow bed. Last edited by FormerMember; 03-22-2008 at 10:41 PM. |
