Old 03-23-2008, 06:44 AM   #1
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
What should the temp guage show cold with the key off?
I just got the wiring and dash all put back together after a complete rewire, but my temp guage doesnt' seem to be showing anything. With the key off and at cold the needle isn't even visable. Any ideas??
I havn't let it run hot enough to see if it will even move due to a water pump leak *its always something*. Just not sure if it should be at cold or fall off all together when off and cold.
ttt
jayharrell is offline   Reply With Quote
Old 03-23-2008, 07:43 AM   #2
muscletrucks
muscletrucks's Avatar
Re: What should the temp guage show cold with the key off?
I would check the wiring from the gauge to the temperature sending unit. It sounds to me like it is grounding out.
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 03-24-2008, 01:01 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
grounding out would pedg it to hot.
I say wait till you fire up the engine... THEN see whats wrong. It may be absolutly fine.
Old 03-24-2008, 04:38 AM   #4
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: What should the temp guage show cold with the key off?
I just did this to my 67 , YOU HAVE TO BUY A NEW TEMP SENDING UNIT !!!
the one for the idiot light and the one for the gauge are different , I went to advance auto part's and got mine it was $4 buck's ,, work's perfect , but with the key off it don't move ,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-24-2008, 04:40 AM   #5
19673ontree
CAN'T FIX NOTHIN
Question Re: What should the temp guage show cold with the key off?
I may have missunderstood , you did not rewire to go from idiot light's to gauges ? you just rewired your already gauge equiped dash ? right
underdash AC
Old 03-24-2008, 08:33 AM   #6
jayharrell
jayharrell's Avatar
Longhorn had it as always. Fired it up and nothing, i put the dash together wrong and had the needle hung behind the bottom out peg. Smart as a mule and just as good looking, my life story. Thanks for the responses.
