gas tanks
guys I need some help please. my blazer needs a new gas tank and i'm having problems deciding which to get which do ya'll think is the better choice the poly (plastic) or a steel tank now keep in mind the reason my tank is junk is because of rust it's been sitting since 1998 my wife says plastic but i am having a hard time deciding could use some help let me know what ya think.
Adam ![]() |
Re: gas tanks
What are your pros and cons concerning the two?
Metal = rust sure but hey, it lasted almost 35 years - right? Poly = ? What's your concern with the plastic? |
Re: gas tanks
check out this site http://www.speedyautoparts.com/find/...EPICKUP67.html
going to get my tank for swap from them |
Re: gas tanks
I just bought a poly tank for my truck
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
Re: gas tanks
Just installed Poly on my 72. Works great, had to get a longer hose from filler neck.
![]() Join Date: May 2007
Re: gas tanks
Call TIm Christian @ Christians Classics 877-654-2287. I just bought a new kit from him last week and they were a pleasure to deal with mine is metal I'll let you know how it fits. _jason
- Jason ![]() ![]() |
#7 | |
Re: gas tanks
thanks but they didnt have one for my year! |
New Member
Re: gas tanks
Does anybody know if ethenol will effect the poly tanks at all? Here in Oregon starting in April our gas will have 15% ethenol in it and I know my dad had to change out all the fuel lines in his boat because of this.
Keepin it runnin!
Re: gas tanks
My only question would be how the poly tanks hold up in our trucks in super cold weather. I know the mounting method works for steel, and I dont know if its a big deal for poly.
My original is still in my K-5, however it has been repaired a few times. For me it would boil down to fixability, price and warranty. Steel I can fix, poly I cannot. So "fixability" is a factor for me. Frank
1970 K-5 4X4 Blazer ![]() 1970 K-20 4X4 Long Bed ![]() "Liberty Means Responsibility, that is why most men dread it" |
#10 | ||
GMCDAC
Re: gas tanks
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
Re: gas tanks
i am getting ready to pull my poly tank off my 72 blazer, let me know if it will work for your truck. also for the other response, ethynol will only effect your fuel lines and maybe carb, but dont worry about your poly gas tank it will be fine
![]() Join Date: Feb 2000
Re: gas tanks
I know I have read from a post or two in the main section that some people have had issues with the plastic tanks sagging. Those posts were probably 3-4 years old and I don't recall seeing anything on that issue recently.
Here is the thread concerning the steel tank fitment issues.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: gas tanks
There is a thread on an aftermarket steel tank where the filler neck is not correct. The poly I installed was the same way.
Re: gas tanks
Yeah I just started putting in my repop tank and the neck is in the worng place. But I guess when life gives you lemons ... From all the treads I could find you have to make the same mods the truck guys are to make having to make. To get around the rear bed cross member once I get mine fixed I'll shot some pics. -J
