Old 03-25-2008, 12:11 AM   #1
sleepertruck72
sleepertruck72's Avatar
Question 72 C20 trailer
I was wondering how much It would be worth to me to swap the rear end out of my trailer for a straight axle. I imagine it would be less weight to pull around for my truck while empty or full for that matter ? It pulls fine thanks to my crate motor but would it help more if I took out the rear end ? I figure it would be good to have as a spare I guess.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 03-25-2008, 12:19 AM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: 72 C20 trailer
if you have the HO52 just pull the axles, drop the 3rd member, remove all the brake components-including the drums, pack the bearings with high temp grease, either saw the axles off or make plates to cover the hubs and bolt another cover in place of the 3rd member ( I cut a flat plate and welded it over mine but another cover will work) and you have a strong and lightweight axle that uses the same spare as your C-20 truck.
dana 60s aren't as easy BUT can be lightened also.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-25-2008, 01:26 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 72 C20 trailer
does 150 pounds make much of a difference?
Old 03-25-2008, 01:39 AM   #4
Re: 72 C20 trailer
The heavy axle helps keep the trailer from bouncing around so much when empty,I`d think.But,what Jerry suggested is a great way to lose some unspring weight and rolling resistance (prolly not much,though).
