Old 03-26-2008, 11:16 PM   #1
bryanw1968
bryanw1968's Avatar
Header choice.....need input.
I bought a set of the Hedman Elite mid length headers a few years ago and they have worked well. However my motor is being held back by the fact that they only have 1 5/8" primaries and a 2 1/2 collector. And, I'm about to jump two steps on the cam and going with a bigger stall and I'll be making power more in the mid-upper range.
So here's what I'm looking for.
1.) A 1 3/4" primary tube
2.) 3" collector
3.) 3/8" flange
4.) long tube that doesn't hang too low
bryanw1968 is offline   Reply With Quote
Old 03-26-2008, 11:22 PM   #2
68c10guy
68c10guy's Avatar
Re: Header choice.....need input.
Sounds like a good combo, i've got 1 5/8 primaries but a 3" collector running into purple hornies dumping behind the cab but what kind of cam are you going to run?
68c10guy is offline   Reply With Quote
Old 03-27-2008, 12:15 AM   #3
bryanw1968
bryanw1968's Avatar
Well, I have an Extreme Energy 284 Comp Cam laying around that I could use.
However, it is a noisey SOB. I have the same cam but 268 in it now and the exhaust valves close so hard that it makes a lot of noise. It almost sounds like your valves around adjusted correctly. Anyway, I'm considering going with the Lunati Voo Doo.
