View Poll Results: Which should i do? | |||
Fix brake line and bleed brakes |
0 | 0% |
Completely overhaul brakes (Drums, shoes, new brake line to fix cracked one) |
1 | 100.00% |
Voters: 1. You may not vote on this poll |
Brake Parts for 67 K10
Where can i find brake parts for my 67 K10? Should i just fix what is wrong, which is a cracked brake line (i believe), or should i overhaul the whole braking system w/ a new Master Cylinder, Drums, shoes, etc, and fix my brake lines?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
Re: Brake Parts for 67 K10
I just bought all the brake parts for my 67 from Car Quest.
ok, so local parts stores. I kinda want to support the board vendors, who has those parts? Most only carry C10 parts, not K10
Gone to greener pastures
![]() Join Date: May 2007
I usually go to my local CarQuest, or NAPA stores.
The parts are usually in stock. And if not, they're usually in @ the store opening the next morning. As for your other question(s), I'd open the job up & see what's needed before buying parts.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Supporting vendors from the board is great.
But if I get home and my shoes are not right, I can run right back up there. Or in my case have them drive a different set to my shop. K series parts shouldnt be any harder to find than C series. |
i agree see what you need and buy localy you can be on the road in no time
common sense isn't so common anymore |
but the front drums have a huge hub on them, which i'm probably going to upgrade to a Warn or similar unit, just for better looks, ease and security
I will try my local parts stores
Would NAPA and the like carry the lines?
