Old 03-27-2008, 09:00 AM   #1
tsetsaf
Temporary Fuel Filler Suggestions
Finally mounted the rear conversion gas tank. Do not have immediate access to a welder or cutting torch. Any suggestions/ photos for temporary fillers through the wheel well? I attempted mocking up a radiator hose but the gas nozzles here in Cali keep shutting off as I try to fill the tank. Took me ten minutes to get 1.5 gallons in.
Thx
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 03-27-2008, 09:52 AM   #2
hogrocket
Junior Member
Re: Temporary Fuel Filler Suggestions
If you pull the end of the hose (the rubber part) all the way back towards you while you pump the gas, it won't keep shutting itself off. It's no different if your filling up a gas can.
hogrocket is offline   Reply With Quote
Old 03-27-2008, 04:35 PM   #3
haysonj
haysonj's Avatar
You need to make sure you have a good vent on the tank. because the fillers are so flat going in the gas backs up in them. I added a 3/8 vent on the opposite side of the tank
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-27-2008, 08:39 PM   #4
tsetsaf
Have the vent already just having issues getting the filler into the wheel well to fill the tank while keeping it elevated above tank level.
California Truck
Old 03-27-2008, 08:44 PM   #5
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
This thread got me thinking about the relocation i'm currently in progress on, should the filler have a baffel or a trap door? I never thought about taking a corner and having it slosh around and out the vent or up into the filler neck.
jayharrell is offline   Reply With Quote
