Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-28-2008, 04:35 AM   #3
Couch
Daily Driver
Couch's Avatar
Re: Nitrous?
if you do it,be prepared to turn into a junky. its addicting as said above. a cheap cheater plate is good to a 250 shot.Plenty. im running one right now.on a stock crank,rods and hyper speed pros(not the best idea). but its had i'd say well over 20 bottles ran through it.im running a shot that dyno proved making 150hp at the wheels. and when it hits it hits hard.lol.hard enough to where if your not on good tire(slicks or drag radials) it'll break loose pretty bad.
but you will need to add more fuel. i took my stock gas tank pickup and drilled a hole next to the original pickup tube and ran a secondary pickup tube that goes to its own electric fuel pump,then to a regulator,then to the solonoid which goes to the plate.2* of timing backed out for every 50hp shot is standard.set the regulator at 5 1/2psi flowing(with the pump running).and flow the fuel line into a cup through a jet.i use a 73 nitrous jet when flowing and make sure the flow doesnt change after holding the solonoid open for a good time(as long as the shot will be held on for). this is to make sure you dont lose fuel pressure and run the shot lean,just making sure your fuel pump can keep up.on mine i have a holley blue electric pump.supplies plenty.then just hook it all up.oh and make sure both solonoids share the same ground and hot(so if one doesnt ground they both dont work.) and put the jets in for the shot you want.and depending on how big it is you may wanna put some 110 in just to be safe. then rock it.lol. just make sure the rev limiter never gets hit on the squirt.bad boogey.
a refill for a 10lb. bottle is usually 30 to 40 bucks.but well worth the fun.
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
