Old 03-30-2008, 05:41 AM   #1
chev74
Addicted to Chevy
chev74's Avatar
Speedometer swapping?
I have just redone my dash, but there is a problem... my previous speedo worked fine, but i bought the white gauge decals to put on a different set- now the newly installed speedo will not stay still!
say im cruising at 50 mph- every 3 or 4 seconds it will click then jump up to 65 mph then down to 40 then sway back and forth til it settles then click again...WHATS THE DEAL?
only thing i can figure is that the speedo cable is binding then releasing- making it spin up
Another problem is that the odometer doesnt work with this new speedo
NOW HERES MY QUESTION
can i swap out to guts of my previous speedo (with the working odometer) and fix my problem?
chev74 is offline   Reply With Quote
Old 03-30-2008, 05:43 AM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: Speedometer swapping?
ALSO- here are a few pics i took of the dash the other morning on the drive to work
Old 03-30-2008, 05:43 AM   #3
chev74
Addicted to Chevy
chev74's Avatar
its not quite as bright as it looks in the pictures... just a crappy phone camera
Old 03-30-2008, 07:12 AM   #4
Country Cadillac
Country Cadillac's Avatar
Im gonna buy a set of those. They are sexy.
1987 GMC R1500 TBI 350 700R4
Country Cadillac is offline   Reply With Quote
Old 03-30-2008, 07:16 AM   #5
andresco50
andresco50's Avatar
Awesome.. but I prefer the original one
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 03-30-2008, 07:42 AM   #6
DESTRO
I have the same problem,but unfortunatly I don't have a fix.
Hope you get one so i can fix mine. Even put a new cable on mine.
DESTRO is offline   Reply With Quote
Old 03-30-2008, 08:09 AM   #7
f.monroe
f.monroe's Avatar
The speedo cable needs to be lubed . Remove it from the back of the speedo and pull it out . Lightly lube it and reinstall the cable into the speedo cable housing and hook it back up . That will probably take care of the problem . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 03-30-2008, 08:55 AM   #8
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Use a fork to pop the needles off the 2 gauges then remove the 2 face screws and swap the faces of the 2 gauges then replace the needle.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-30-2008, 01:12 PM   #9
chev74
Addicted to Chevy
chev74's Avatar
Thats EXACTLY what i thought to do. Just wanted to make sure it could be done before ripping into a good speedo. Ill reuse the guts of the one that worked before installing this new one... plus the numbers are whiter anyway so i can read the mileage
THANKS Ble
Old 03-31-2008, 01:39 AM   #10
chev74
Addicted to Chevy
chev74's Avatar
got those speedo guts swapped out... RUNS LIKE A CHAMP
