Old 04-02-2008, 09:05 PM   #1
bestchevyfan
How To ?????????
I Need To Know How To Remove A Cab,or The Best Way To Do It.thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 04-02-2008, 09:25 PM   #2
1969K10
1969K10's Avatar
Re: How To ?????????
A side from this being very vague. there are 6 bolts that hold it to the frame. And then there are the wires on the engine. fuel line & tranny lines if an auto. And brake lines. other than that, get 1 or 2 buddies to help pick it up. they aren't very heavy if you've taken out the junk.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-02-2008, 10:04 PM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Park it on a street in East LA for a couple of hours...LOL! I'm just being a smart a$$! Disconnect the steering, parking brake, ground strap and front clip while you are at it. The front clip will come off with about 8 bolts and will make pulling the cab much easier.
Are you just replacing a badly rusted cab or do you have other plans? The major rust areas can be repaired without removing the cab. If you have major firewall/cowl rust or drip rail rust along with the standard rockers, corners and kick panels then it is best to just replace the cab...but I am sure you already know that. Have fun!
Remove the tank, seat and doors before lifting it off since it will make it much lighter.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-02-2008, 11:46 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey bestchevyfan!!!...
Check this thread out.....it's a one man cab and bed lift!!!!....
http://67-72chevytrucks.com/vboard/s...d.php?t=219353
Hope this helps after you disconnect everything!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-03-2008, 02:20 PM   #5
tommypic
tommypic's Avatar
then get some of your buddies its right off then
tommypic is offline   Reply With Quote
Old 04-03-2008, 03:27 PM   #6
You can take an engine hoist,slip it inside with a 4x4 fastened to the top,and raise it up.
Old 04-03-2008, 04:31 PM   #7
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Just restore everything on the front end and just before you put it all back together, take the cab off like I did. Hope you got a lift.
Just watch the picture backwards.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 04-03-2008, 04:49 PM   #8
bestchevyfan
Going To Pull A Rusted 72 And Replace It With A 67 Barn Find. Thanks,buddy
Old 04-03-2008, 07:53 PM   #9
streetstar
streetstar's Avatar
The way Special K said is a way i have done it as well --- my contraption i rigged up to do it basically did the same thing Rkcrwlin's rig does, but was not as clean looking or permanent (his plans for 1 man cab/bed lift)
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-03-2008, 08:53 PM   #10
whatnow123
whatnow123's Avatar
Get a supercharged 454 and a set of slicks. Install both. Remove the bed and then the bolts that hold the cab to the frame. Start the engine, floor the gas and the cab will slide right off the frame right on the ground. Same idea as pulling the tablecloth out from under a set table. While this probably isn't the best way, it is the most exciting.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 04-05-2008, 01:16 AM   #11
Jwalk1972
Jwalk1972's Avatar
Hello Stllookn,
I noticed you had a couple comments about getting a new cab if you have rust in you drip rail. Could you take a look at my pictures? I am thinking about having some patch work done or replacing the drip rail, but i know almost nothing about working on trucks.
I am not familiar on how to guide you to the thread I posted but it says" A newb from Los Angeles....I love this forum".
jwalk1972
Jwalk1972 is offline   Reply With Quote
Old 04-05-2008, 01:45 AM   #12
HoupPhotography
Nice
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 04-05-2008, 01:51 AM   #13
blukangoo
blukangoo's Avatar
Here is the link to what you are talking about: Click Me!
If I didnīt have the lift to get the cab off I would have went with the one with the engine lift. Somebody also said it is lighter without all the junk, I didnīt see any Junk in mine, itīs all worth the same as gold.
Somebody said there are 6 Bolts holding the Cab to the frame, I only had 4. The trickiest part was getting the Steering column out and back into the steering box. The rest is just wires an cables.....and the screws holding the fenders and cowel on.
Have fun doing it.
My C10 Diary
Our cars:
Last edited by blukangoo; 04-05-2008 at 01:53 AM. Reason: I get a kick out of editing.
