Active Member
![]() Join Date: Jul 2007
Bug season is here. Need Ideas for screening
I took my truck out for a nighttime test drive and picked up some moths and other assorted bugs on my radiator. In the spring we have a problem with grasshoppers, moths, love bugs, etc.
What are you all using for screens and where did you place it? Right behind the grill or in front of the radiator? |
Re: Bug season is here. Need Ideas for screening
i just use window screen in front of the radiator but want to have a edge soen on and snaps like a tonue cover to remove for cleaning
common sense isn't so common anymore |
Active Member
wibilly, I was thinking of using window screening myself but felt it might be too restrictive. Does it cause your truck to run warmer than normal?
