Old 04-03-2008, 06:59 AM   #1
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Brake Question
Probably nothing like the others said, but If you reused your crush washers under your banjo bolts, they can seep fluid if you don't really crank the banjo bolt down. That situation caused the only caliper leak I have ever seen.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
