How many ounce of oil do these trucks w/factory air get? Also, how many lbs of freon. Im putting the R134a freon on it. Thanks!
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
Re: A/C recharge oil and freon?
Don't call it freon, R112 was freon, call it refridgerant, i got b'd at at a parts store for calling it freon, idk why
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
![]() Join Date: Oct 2005
I just did this last summer and cant for the life of me remember how much it was. I think it was 80% of what the system holds for r12. As far as oil I dont remember. someone will chime in and give you the answer. Good luck.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
![]() Join Date: Aug 2004
The factory assy manual gives the specs for oil and r-12, roughedup72 is right about the 80% thing.
The assy manual shows 3.25lb r-12 and 10oz of oil. So that calculates out to 2.6lb of 134. The manual says something about the compressor being shipped with some oil in it, so you may want to add a couple of ounces if your system is all cleaned out.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Broken Down
Pag oil, or ester for it R134 and Mineral oil for R12.
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
Thanks everyone!
Can't you use the PEG oil and ester with the R12? I thought the only issue was using mineral oil with the R 134a
Broken Down
You can use ester in R12 but I have heard you are not suppose to use Pag with R12. And I have nevery used Pag with R12.
POLYOLESTER (POE) OIL
Definition: A type of compressor oil that is compatible with both R-134a and R-12 refrigerants, as well as residual mineral oil that may still be in the A/C system. POE oil is often used when retrofitting an older R-12 A/C system to R-134a. Switching an older R-12 system to R-134a does not require a lot of modifications in most instances. Changing the accumulator or receiver-dryer, removing the old compressor oil and replacing the high pressure switch is generally all that is needed. For more information, consider purchasing the R134A RETROFIT GUIDE on this website http://www.aa1car.com/carleyware/retrofit.htm
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 04-04-2008 at 12:18 AM. |
