Old 04-02-2008, 06:04 PM   #1
c10beezer
c10beezer's Avatar
Plumbing to gas tank
Can someone help me out here? I have a 68 c10 that I bought in pieces (someone elses project). I am running my fuel lines to the stock tank behind the seat. On the sending unit I have two lines 3/8 and I am guessing 1/4. The 3/8 would be the feed but would the return be that small? My carb return is a 3/8 line. My other question is on the passenger side of the tank there is a 3/8 fitting what is that for? Thanks for your help.
c10beezer is offline   Reply With Quote
Old 04-03-2008, 06:42 PM   #2
c10beezer
c10beezer's Avatar
Question Re: Plumbing to gas tank
Am I the only crazy one who is going to run the stock tank?
Old 04-03-2008, 08:02 PM   #3
haysonj
haysonj's Avatar
I'm not sure but I don't think that is a stock tank for a 68. My 69 only has the one line out of the sending unit and unless you have a big block it will not be 3/8
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 04-03-2008, 08:11 PM   #4
cameeks
Long Fleet Club
cameeks's Avatar
sounds like a tank from a truck with a charcoal canister. The 3/8 is the feed and the 1/4 would be the vent.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 04-03-2008, 08:13 PM   #5
cameeks
Long Fleet Club
cameeks's Avatar
all the tanks are 3/8 feed lines.
Chris Meeks
Old 04-03-2008, 08:39 PM   #6
Jim_PA
Mine is 5/16, currently in the process of upgrading to 3/8 with all new lines up to the carb.
Jim_PA is offline   Reply With Quote
Old 04-03-2008, 08:41 PM   #7
c10beezer
c10beezer's Avatar
It may be a later tank, the guy I got it from bought a wrecked 72 for parts.
Let me describe the tank an fittings a little better. There is a vent at the filler, sending unit has two lines 3/8 and about 1/4, passenger side of tank has another line in the corner it looks to be a little smaller than 3/8. Is ther a way for me to still use this?
Old 04-03-2008, 08:44 PM   #8
haysonj
haysonj's Avatar
If you look at the sending units on LMC only the big blocks are 3/8 the rest are 5/16 Just rechecked LMC I was wrong the two barrel carb is 5/16 and the four barrel is 3/8
Old 04-03-2008, 09:04 PM   #9
cameeks
Long Fleet Club
cameeks's Avatar
Umm
When I was searching for a tank I have never saw where they asked what size I needed and the one I got was 3/8. I stand with a foot in my mouth
Chris Meeks
Old 04-03-2008, 09:20 PM   #10
70inline6
You can still use it but as written, it is from a charcoal canister equipped vehicle. In my research, all V8's used the 3/8 sending unit line and the 6's used the 5/16. You can either cap the vents or plumb the sending unit and pass side vent (t'd) to a canister.
Don't plumb them directly to the carb or your tank will be under constant vacuum. It couldn't hurt to find a junk yard canister and plumb it in - I can smell fumes in my garage whenever I don't drive mine for a day or two.
70inline6 is offline   Reply With Quote
Old 04-03-2008, 09:24 PM   #11
cameeks
Long Fleet Club
cameeks's Avatar
Why couldnt he just cap off the other lines. My '69 tank only has one line out to the carb and that is factory.
Chris Meeks
Old 04-04-2008, 02:43 AM   #12
c10beezer
c10beezer's Avatar
Ok. if the line on the passenger side is for the canister filter, the smaller line on the sending unit is a return.? I really appreciate the help.
