Old 04-03-2008, 08:40 AM   #1
short69
short69's Avatar
rusty bolts- need help
I am currenly in the dissassembly stage of my bed and have two new bedsides ret to go. I got the tailgate off and the front panel unbolted with no issues, however, the bolts that are in the inside "angle" are small cariage bolts and after a few turns, the bolt and the nut turn together and make no progress. So, does any one have any tips on how I get get these things off quick like? I wont be re-using them so the more destructive the better, Thanx.
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 04-03-2008, 08:43 AM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: rusty bolts- need help
Use an angle grinder? Or drill out the bolt heads? Hacksaw? Torch?
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-03-2008, 08:43 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
If you have a welder you can weld a nut on the bolt head.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-03-2008, 08:44 AM   #4
truckdude239
truckdude239's Avatar
pb blaster is your friend
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-03-2008, 08:49 AM   #5
short69
short69's Avatar
wow! thanx for the feedback guys!! I was thinking about a torch and a air chisel, but some of your suggestions may be a little more do-able.
Old 04-03-2008, 09:26 AM   #6
Willys47
Willys47's Avatar
you may be able to tighten the up and keep tighting them till they bust off. I do this all the time to get rust bolts off on these boxes
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-03-2008, 09:59 AM   #7
CG
BlahBlahBlah
On small bolts like that if you can get a vice grips on em, nose grip not a side grip, sometimes you can just rock em back and forth and they will break off.
Too bad both sides are spinning. The tighten em till they break is another good way, as suggested already.
Old 04-03-2008, 12:43 PM   #8
chip46wis
Just tighten them about 1/2 turn-they will break-----easy to do.
chip46wis is offline   Reply With Quote
Old 04-03-2008, 02:24 PM   #9
JQ-72
JQ-72's Avatar
2 words - oxygen, acetylene. Whenever I pull a bed or take one apart, I go ahead and get my torch rig out. I usually cut the nuts off without even trying to wrench them off - especially wood beds!!
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 04-04-2008, 07:48 AM   #10
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I took a small grinder and cut a slot so a friend could hold them with a big flat screw driver...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-04-2008, 07:56 AM   #11
rick0312
rick0312's Avatar
check out the hint after #14!
http://www.mar-k.com/67-72conv.pdf
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
