04-01-2008, 04:34 AM | #1 |
Sierra Grande Club
Steering column questions….
I pulled my steering column out in preparation for paint.
I needed to remove the small bolt on the end of the shaft for the added clearance and the bracket it was holding was broken. What does it do, I see there is an angled slot perhaps for adjustment? Are there replacement parts for these or will I need to get them from a junk yard? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 04-01-2008 at 04:45 AM. Reason: pics |
04-01-2008, 05:36 AM | #2 |
go cyclones
Re: Steering column questions….
I think I may have the same problem... subscribed
04-01-2008, 11:44 PM | #3 |
Sierra Grande Club
Ttt
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
04-02-2008, 01:22 AM | #4 |
is that a standard (manual) on the column shift? Reason I ask is that I've seen that angled slot and band use to properly adjust the shifting mechanism(s) (that make sense?)... Don't know if it's on the auto columns too....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
04-02-2008, 03:06 PM | #5 |
Sierra Grande Club
Its the auto column. I'm wondering how necessary that part is?
s/t
04-05-2008, 11:42 PM | #6 |
Sierra Grande Club
I went to the salvage yard and got new straps to replace my broken one.
What does this adjustment do & how do you adjust it? I need to pull it off to paint everything and want to make sure it works properly after I'm done. JDB- if you need one strap I can send it to you....LMK. s/t
04-05-2008, 11:59 PM | #7 |
I don't think it does anything; When I put my column back together, I adjusted it about the middle of the slot, which is about where it was when I took it off. Really, that is the only place you can put it, because too far one way or the other and the bolt won't line up with the hole. BTW, mine is a manual non-linkage column (4 speed on the floor).
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
04-06-2008, 04:51 PM | #8 | |
Sierra Grande Club
Thanks Dan, My guess is it takes up slack in the column and probably more so with the auto linkage. I'll mark it and try to move it around and see if it makes it tight etc. I'm sure it's not to hard to figure out. I was hoping someone has done this before. s/t
04-07-2008, 05:31 AM | #9 |
Sierra Grande Club
Here’s what happens when you take the 5 bolts off the two lower straps…….
s/t
