Old 02-22-2008, 03:30 AM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Plained off firewall
Hey Guys I have a question.
When you plain the Firewall complete...... Where does the Wiring get routed to?
Like the Engine harness and light harness. Where do you all put em?
Also is there any pics?
Angelse68cal is offline   Reply With Quote
Old 02-22-2008, 04:05 AM   #2
Re: Plained off firewall
You can run it across the lower side of the firewall and behind the engine where it is not noticed as much.
Old 02-22-2008, 04:41 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I am going to bring mine out of the floorboard in the corner, but the E-brake.
Old 02-22-2008, 05:19 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Angels, it can also be run to the side and above the fenderwell to hide the lighting loom.One of the major parts of doing this is rewiring and rerouting the hoses for the heat/Ac.Also the term for this is "Shaving" the firewall.I guess it would be worthwhile to build a terminology thread for FAQ's since some of the younger crowd don't know the terms and seem to be reinventing them.For instance a
Body Drop = Channeled( since the 30's-or so)
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-22-2008, 08:01 AM   #5
68Stepbed
68Stepbed's Avatar
Like this?
Mine comes out behind the rear of the inner fender for the headlight and front end stuff. The engine wiring comes out just behind the engine.
Also, my speedo cable comes in from the bottom.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-22-2008, 09:04 AM   #6
crazy longhorn
Fabricate till you "puke"
I guess Ill have to change that "body drop" in my sig , to channeled....there are still guys around that know what it means Reguardless of terminology, its still good to see the younger as well as the older crowd playing the game crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-08-2008, 03:35 AM   #7
Angelse68cal
Cochino_Racing_909
Can you guys who are plaining the fire wall Show some in progress pics of where you are running your wiring before its all put together. Thanks
