04-12-2008, 01:39 AM | #1 |
PITbut
Thoughts on this air system?
http://www.viaircorp.com/10003.html
What do you guys think.. Just running rear airbags.. Of course i need the bags still... Thoughts??? |
04-12-2008, 01:40 AM | #2 |
Re: Thoughts on this air system?
Using the stock trailing arms and stuff?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
04-12-2008, 02:03 AM | #3 |
PITbut
04-12-2008, 02:54 AM | #4 |
Quick Hijack! Do you need rear shocks with air bags on the rear? Dumb question I'm sure, but I don't know.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-12-2008, 03:03 AM | #5 |
someday it will be done!
yes rear shocks are needed.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
04-12-2008, 03:23 AM | #6 |
PITbut
04-12-2008, 03:47 AM | #7 |
senior member
i have a viair compressor and i like it its a bit noisy but other than thats its good
69 GMC bagged |
04-12-2008, 03:53 AM | #8 |
It would work fine w/one exception: the single control. By that I mean you'll have up/down capability of both bags together vs. separate. Controlling bags together will 'work', but you get air shift or compression of one bag as the vehicle leans in a corner forcing the other bag to extend which exaggerates the leaning issue.
A dual control panel would work better (one paddle controls L; one paddle controls R). This would eliminate the leaning issue.
04-12-2008, 04:42 AM | #9 | |
PITbut
04-12-2008, 06:43 AM | #10 |
Buy a second single controller or a dual controller.
I know ART sells a dual-needle/single gauge dual pnuematic controller. I'm not sure if SuicideDoors offers one but it's worth checking out.
