Old 04-11-2008, 07:29 AM   #1
tablloyd
tablloyd's Avatar
nasty stuff in my oil?
I found all this junk about four months ago when I switched my valve covers out. Now I went back to get the casting numbers off of my heads, and it was back.
That was the drivers side. I cleaned it up, then went to clean up the passenger side and there was none there. Completely clean apart from the few oil spots. Should I put some engine cleaner in there?
tablloyd is offline   Reply With Quote
Old 04-11-2008, 07:39 AM   #2
berencam
berencam's Avatar
Re: nasty stuff in my oil?
pic isnt loading...
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-11-2008, 07:50 AM   #3
tablloyd
tablloyd's Avatar
Originally Posted by berencam View Post
pic isnt loading...
sorry about that. here it is
Old 04-11-2008, 08:10 AM   #4
berencam
berencam's Avatar
looks like some water/coolant got in there. Possible bad intake gasket?
Old 04-11-2008, 08:20 AM   #5
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Nasty chocolate milk looking mess. Coolant leak. Hows your oil look?
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 04-11-2008, 08:24 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
being that it's only on one side...
How often does the truck get driven?
Do you have a proper PCV system... PCV valve on one side, and a breather or fresh air hose to the air filter on the other side?
If by engine cleaner, you are talking about the motor flush... I would recomend never putting that stuff in your engine.
Old 04-11-2008, 09:25 AM   #7
Mint68
Mint68's Avatar
I agree. Is the oil cap on the valve cover or on a tube. If the cap is clean, it doesn't seem ver serious.
Mint68 is offline   Reply With Quote
Old 04-11-2008, 03:56 PM   #8
greasy68
greasy68's Avatar
It does look like water/coolant mixed with oil. From what is the question. Unfortunately I know what it looks like pretty well. I had the oil light come on in an old truck and when I pulled the dipstick out it looked like that stuff on the stick. No bueno. It had circulated it everywhere by then and very expensive/time consuming to get fixed. It looks like your problem is much less severe but check the oil just in case.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 04-11-2008, 08:06 PM   #9
tablloyd
tablloyd's Avatar
Well it was on the PCV side, and none of it got through they system into my oil. My breather is clean too. I'll just reinstall my intake and see if it fixes the problem
Old 04-11-2008, 08:11 PM   #10
Sammy
Seen that happen getting the engine clean by washing with pressure washers & such. Also washing around the ol point style dist. and crackin caps at the car wash.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-11-2008, 08:26 PM   #11
cdowns
cdowns's Avatar
i'd also suspect bad pcv system as the cause
Old 04-12-2008, 12:21 AM   #12
Huck
Huck's Avatar
I would change to a new PCV valve, make sure it is hooked up to constant vacuum. Then change to a high detergent oil like CASTROL. Run it for a while and see what happens. When - if- you change the intake manifold gasket, make sure you use thread sealer on the bolts as you can get coolent coming right up the bolt threads and that can get into the oil galley's. Usually when that happens, you will see coolent on the intake it's self and if into the oil, it would be visable on both heads.
Huck is offline   Reply With Quote
Old 04-12-2008, 07:49 AM   #13
tablloyd
tablloyd's Avatar
The PCV vaulve is new, actually. And I'm running mobile 1 synthetic, I'm not sure if thats high detergent or not. But, being that I'm the one who installed the intake in the first place, it probably was my own fault that it leaks (assuming thats the problem). I just put some of the RTV silicone on each of the bolts before putting them in, maybe I'll try something different just to be safe.
