03-17-2008, 11:17 AM | #1 |
Block hugger headers
Do any of you guys know if these will fit our style of trucks? I found a set of ceramic coated street rod headers that I may not be able to pass up if they will fit my truck. The only thing of concern to me is whether or not they will clear the motor mounts on my 4x4. I figured that if it had been done before, somebody on this site has tried it. Thanks in advance guys. ...Joe
I'm not speedin'! I'm qualifyin'! |
03-17-2008, 03:02 PM | #2 |
STILL PLAYS WITH TRUX
Re: Block hugger headers
I can't remember the eng. mount location on a 4by but if there fwd of mid block they should work.
Get 'em if they don't work sell 'em. |
03-17-2008, 07:37 PM | #3 |
Insert Witty Text Here
You might check with cochino12. He had some on his yellow 2wd and he has had at least one 4wd. He probably knows the answer to your question.
Slonaker |
03-17-2008, 08:13 PM | #4 |
Old Time Rodder
Have a set of Sanderson on my 79 w/sbc, had to cut one mount just a little to clear, I believe it was the driver side. Have had them on for probably 8 years.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980) Replacement cab had A/C which now works, made a real truck out of it 84 MC 305 350TH 3.08 4 wheel disc finally My daily driver again |
03-18-2008, 12:15 AM | #5 |
It followed me home?
I had some sandersons on my 2wd, nice but really spendy
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-18-2008, 12:30 AM | #6 |
Wow! Yeah that's exactly what I was looking for. Did you have any problems with clearance with the motor mounts? Do you have any pics of the driver side? Thanks for responding! ...Joe
03-18-2008, 12:32 AM | #7 |
No problems with fitment at all, I really liked those headers.
03-18-2008, 01:07 AM | #8 |
Thanks! You really helped me out a LOT in making my decision! I'm going to buy those headers for the 350 that will be going in my truck! I'll just have to get a custom exhaust system made for them, but I would have needed to do that anyway. These headers are priced so good that I just don't think that I can pass them up. They are the ceramic coated ones, so they should last for quite a few years. Many thanks again! ...Joe
03-18-2008, 06:17 AM | #9 |
I have two sets, neither will clear without serious hacking
04-14-2008, 10:10 AM | #10 |
I got my motor mounts today that I bought from a fellow board member and Missourian, mike in mo. I bolted them up and test fit the headers that I bought, and they fit perfect! No clearance issues whatsoever!
These are just like the ones that I bought for my truck from the same seller that I bought mine from just in case any of you other guys are considering buying a set. Just thought that I'd pass this along. This is a lot cheaper, and in my opinion, better looking way to go than the long tube cheapo headers. I'll have to get a custom exhaust made for them, but would have needed to do that with long tube headers anyway. These cost about the same as the painted steel cheapo headers that will rust out in just a few years, and they are made a whole lot better! Bigger tubes, and a lot thicker flanges along with a ceramic coating! ...Joe http://cgi.ebay.com/ebaymotors/SB-CH...mZ270226576317
