#26 |
![]() Join Date: Feb 2000
Re: Hacked Dash Option's?
Looks like a great plate. Yep, better anti-bling that with some flat black or something.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#27 | |
![]() Join Date: May 2006
![]() Quote:
![]() Every thing you do comes out looking good, why should this project be any differant! Nice work, must feel good to be playing with your own stuff again
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-16-2008 at 02:04 AM. |
#28 |
![]() Join Date: Mar 2008
Looks good. Just neet to knock the shine off.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
#29 |
Did a quickie install for the lights/switches and toggles, patch held in dash with duct tape.
Top toggle is my electric fan, push left and the green LED comes on telling me it's running at low speed...push right and the red one comes on saying it's running on high. Toggle switch is a On/OFF/On - three position switch. Interior winch switch is now alot easier to reach than before. (found out one of my solenoids is bad playing with it today) Even mounted the factory ACC-OFF-ON-START plate. ![]() |
#31 |
Future TOTM Winner
So, I guess I will ask a dumb question...are you going to put the radio back in it? I like the way it turned out so far!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#32 | ||
#33 |
How about some nutserts, makes it real easy to drop the panel and track down a short...
I have to put one in my upper windshield post, as the PO thought a slip in sheet metal sert would work....NOT! Luckily the hole is just alittle small and be drilled out to 3/8" Nice work so far, enjoy seeing your mods. Fitting for a 3X TOTM ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-16-2008 at 07:21 PM. |
#34 |
Installed and Working
Finished up the wiring, turns out I was able to shorten a few which for me almost never happens.
Decided to simply use some black self tap screws, always liked the look of em anyway. I like these mods that are fairly quick, simple and make my life easier. |
#35 |
Re: Installed and Working
Maybe I should have same the ignition switch label thing. I broke mine off with a screwdriver so I could install my panel
71 Blazer Build Thread
http://pirate4x4.com/forum/showthread.php?t=553755 www.powellvalley4wheelers.com |
#36 |
Nice work as usual, no more ugly hole to look at
#38 |
#39 | |
Its lookin' like a Blazer!
#40 |
Looks good VT. Have you thought about maounting some gauges in there as well?, it would look goos with aome autometers in there
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange |
#41 |
Can't wait to retire!!
Looks really good Kurt!
Maybe you should start producing these for an after market part... Hmmm. And BTW, Thanks. ![]()
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#42 |
#43 |
Would be nice to have a trans. temp. gauge. Always wanted one of those...JAT
#44 |
#45 |
#46 |
Noob
![]() Join Date: Feb 2008
When I restored my 69, I had a similar issue but I cut the piece I needed out of a donor truck and welded it in. I just love the original look with the factory style radio too much to have put a piece of aluminum in there. To each his own.
#47 | |
![]() Take the time to start up a thread showing your truck, it looks good sitting on the trailer but I didn't see any interior or dash pics in your sale post. Which leads me to the next question...if you have such a love for these old trucks, why ya sellin' it? |
#48 | |
Noob
![]() Last edited by hotrodkev; 05-17-2008 at 03:56 PM. |
#49 |
#50 |
Noob
