Old 04-16-2008, 08:27 AM   #1
BUG1500
1960 To 1964 Front Suspension
I Have A 1960 C10 With A Torsion Bar Susp. But My Buddy Has A 1964 Coil Suspension. Will This Work On My Truck And What Mods Are Needed? Thank You Anthony
1960 CHEVY C10
1967 CHEVY C10
BUG1500 is offline   Reply With Quote
Old 04-16-2008, 08:36 AM   #2
68c10owner
68c10owner's Avatar
Re: 1960 To 1964 Front Suspension
you will need the complete crossmember and suspension. It will bolt right up to your 60. I`m putting a 73 crossmember on my 62 whenever I get the time to actually work on it.
Anthony
68c10owner is offline   Reply With Quote
Old 04-16-2008, 04:27 PM   #3
jchav62
1962 C-10
jchav62's Avatar
You will have to use a 73-87 front suspension. On 60-62's with the torsion bar setups, those frames are a different than 63-66.. A little wider, I believe....
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-16-2008, 05:15 PM   #4
68c10owner
68c10owner's Avatar
It`s my understanding that the 73-87 crossmembers will fit from 60-72 chevy trucks. That being the case the 64 complete front crossmember and suspension should bolt up to the 60 frame. What am I missing?
Anthony
Old 04-17-2008, 12:17 AM   #5
63sbssbbw
UCA63
63sbssbbw's Avatar
Pretty sure it will fit,
I think the rear is wider,front is the same,lees a coulpe of holes to drill
I will be doing the same swap soon,78 onto my '61
More input would be great
Thanks T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
