Old 04-17-2008, 06:52 PM   #1
svgould
Active Member
svgould's Avatar
Re: Got a fix for the Coys on our trucks
Can I get the autocad drawing emailed to me please. I will PM you me email address.
Thanks,
Originally Posted by fatboys69 View Post
Just got my Coys and the fronts wouldn't sit flat against the hub. After talking to a few board members that have the wheels and saw how they overcame the situation, I had these spacers made. They space the centercaps out 1/4" so the wheel will bolt flat to the hub. I have an autocad drawing that I can email to anyone who would like it ( so they can have someone cut them out ). I had mine cut at work ( we have a laser ), I used 1/4" thick aluminum plate.
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 04-17-2008, 07:33 PM   #2
see ten
WTB this ad
see ten's Avatar
That's pretty sweet! A spacer like that would of let me run the bullet caps that came with my Cruzers. I ended up going with a knock off center instead. Didn't really bother me as the bullet caps were plastic! You would think when they charge over $700 a wheel you'd at least get a metal center cap!
see ten is offline   Reply With Quote
Old 04-17-2008, 08:44 PM   #3
fatboys69
fatboys69's Avatar
AMEN BRO !!!!! At least mine are die cast aluminum !!!
fatboys69 is offline   Reply With Quote
