sm 465 trans
i have a sm 465 trans at least that is what i was told is in it if you guys can take a look and make for shure and also if you know witch of the items that are circled is the switch for the backup lights if anyone knows thanks
![]() Join Date: Apr 2000
Re: sm 465 trans
yellow is vent
green is back up switch blue a top fill plug???
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
Re: sm 465 trans
hey thanks alot
Re: sm 465 trans
yup, that is definatly a sm465 but I do know there are two different styles and the only difference is the number of splines, take the number off of the trans and type it in on google that is what I did with mine and one of the links tells you everything about the two differnet styles and the gear ratios
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
Re: sm 465 trans
you have the two wheel drive version. the yoke on the back says it all. The 4x4 version goes right into an adapter for the x-fer case.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
#6 | |
Re: sm 465 trans
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 04-18-2008 at 03:32 AM. |
