350 guys PVC
Does it matter what side your put the PVC plug/valve?
And the breather on the other side.... Can these be switched around or is it set? might be a dumb ? ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
67-72 Addict!
Re: 350 guys PVC
It can be on either side.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Oilfield Trash
Re: 350 guys PVC
Dont matter which side it on, ive ran them on both sides with no trouble.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Chasin' the Dream
Re: 350 guys PVC
Re: 350 guys PVC
thanks guys
now I can rest...lol
![]() Join Date: Apr 2008
Re: 350 guys PVC
I believe its called a pcv valve.
Chasin' the Dream
Re: 350 guys PVC
Positive Crankcase Ventilation
its all about the +6 inches
Re: 350 guys PVC
no dumb questions
Re: 350 guys PVC
What about not running a pcv and just having a breather on each side?
What's the downside?
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
Chasin' the Dream
Re: 350 guys PVC
A PVC valve vents the block into the carburetor and out the exhaust. A breather vents the block into the engine compartment. You choose.
Re: 350 guys PVC
does the carb need the hose going through it to function right?
I'm all for 2 breathers |
Re: 350 guys PVC
The key word is positive. A breather is a passive vent.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
Re: 350 guys PVC
A good comparison of breathers verses PCV system;
Lest say you have a room filled with smoke, toxic gasses, acid in the air, and oil droplets. On one wall, there is a window, and on the oposite wall, another window. Open the windows to clear the air in the room. That's the breather set up. Place a window fan that spins an insiane RPM and is able suck the room clean in a matter of moments, with fresh air coming in the other window supplying fresh air. That's the PCV set up. |
#15 | |
someday it will be done!
Re: 350 guys PVC
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#16 |
Re: 350 guys PVC
Describing it like this would make anyone understand... even my mom, and it would take her 20 min to figure out where to put the oil.
#17 |
Re: 350 guys PVC
exactly.
#18 |
![]() Join Date: Mar 2008
Re: 350 guys PVC
thanks highsteel for the link
![]() ![]() ![]() 1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
#19 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Re: 350 guys PVC
Breathers look cool, but they get oil all over your nice shiny valve covers. If you don't clean it all the time, it runs down to your ex. manifold and makes a stinky, and the ladies don't like the stinky.
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#20 | |
Re: 350 guys PVC
![]() SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
