"brand new second-hand"
anyone changed corp 10bolt gears?
I got to change something. I recently changed to a 468 bb and rebuilt the turbo 400 but the gear in the rear is too low-4.10 or a 4.56. Has anyone changed out ring and pinion for this (10 bolts on the cover) and drop-out front rearend. The truck is a 69 c-20. Are there any suggestions for swapping to a later rearend and what would that be-I have a coil spring set-up. Thanks
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
its all about the +6 inches
Re: anyone changed corp 10bolt gears?
that is the eaton rear end, you won't find a better gear than a 4.10
